Unity Upgrade 4.03 to 7.x ???
Dec 30th, 2009
I am upgrading a Unity 4.03 install to Unity 7.x. There is one exchange 2003 server as the partner. The 7.x install will be on new hardware and I just need to migrate the users from one server to the other. My question is can I install the 7.x software and connect it to the Exchange server while Unity 4.x is still running on this Exchange server? And if so can I then just use GSM to migrate the users?
Overall Rating: 5 (1 ratings)
Ginger Dillon Mon, 01/11/2010 - 11:47
  • Blue, 1500 points or more
Hi -
Yes, you can do this.  You will need to digitally network both servers together and configure into same dialing domain.  See this link - Task for Digital Networking - http://www.cisco.com/en/US/docs/voice_ip_comm/unity/403/networking/guide/ex/NET_0200.html#wp1177819. You can disregard the sites info related to Exchange 5.5 since you are running Exchange 2003.  You will also need to set-up the permissions required to move users from the 4.X server to the 7.X server for GSM, including the most current version of the tool - http://www.ciscounitytools.com/Applications/Unity/GSM/GSM.html
There is an open caveat for version 4.0(3) using GSM that has a work-around:
CSCec05165
GSM: After move, old Cisco Unity server still lights the MWIs of moved subscriber. After moving a subscriber with the Global Subscriber Manager (GSM) tool, the old Cisco Unity server continues to attempt lighting and extinguishing the MWI for the subscriber.
Condition
This problem occurs when one or more subscribers are moved with the GSM to a new Cisco Unity server.
Workaround
Restart the AvNotifierMgr service on the old Cisco Unity server that the subscriber was moved from.
Just in case you have auto attendant applications or other Unity stuff you want to move to the new server, I recommend you check out the COBRA utility - http://www.ciscounitytools.com/Applications/General/COBRAS/COBRAS.html
Hope this helps!
Ginger
Jaime Valencia Mon, 01/11/2010 - 12:06
  • Cisco Employee,
  • Hall of Fame,
    2011
Just to add something to the great info from Ginger, for COBRAS you would need 4.0(5)
Requirements/Special Notes
Backup supported for Unity 4.0(5), 4.1(1), 4.2(1), 5.0(1), 7.0(2) with Exchange or Domino as the back end or with Connection 1.2 or 7.0(x) and later.
http://www.ciscounitytools.com/Applications/General/COBRAS/Help/COBRAS.htm#_Toc248725739
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
