WLC: Block Client
colmgrier
How to block off a client from access point if sending too many requests on a WLC 4400.
George Stefanick
Monitor-->clients (right hand side)---> click on the blue box next to the problem client and press disable
enjoy!
Naveen Kumar
Level 4
Level 4
Using this link you can configure the peer to peer blocking of clients:
http://www.cisco.com/en/US/docs/wireless/controller/7.2/configuration/guide/cg_wlan.html#wp1161858
or you can use this method:
Monitor-->clients (right hand side)--->  click on the blue box next to the problem client and press disable.
Leo Laohoo
Or you can try CLI.
Command:  config exclusionlist add AA:BB:CC:DD:EE:FF "Comments"
