Create NAR using RDBMS
Answered Question
Dec 30th, 2009
Hi All
I want to create Network Access Restriction using RDBMS.  I already imported all my NDGs and AAA Clients using this feature, now I want to create NARs that same way.  I didn't see anything regarding Action Code for adding NARs.
Is it possible with RDBMS?
Note : I must use RDBMS cause i'm using ACS 4.2 on a SE box.
Correct Answer by Jatin Katyal about 7 years 2 months ago
Reasue:
There are actions listed only to add/delete the "Network Access  Restrictions" .You can not add/delete/modify Shared NAR.This can be a new feature in the enhancement list of ACS.
Action Codes for Initializing and Modifying Access Filters:
http://www.cisco.com/en/US/docs/net_mgmt/cisco_secure_access_control_server_for_windows/4.
2/user/guide/A_RDBMS.html#wp78048
You may go for user/group level NAR that is possible with RDBMS.
JK
Plz rate helpful posts-
Overall Rating: 3 (2 ratings)
Administrateurs... Thu, 12/31/2009 - 05:49
Hi forgot something.
I try to create Shared NAR, not user or group level's NAR
I didn't find anythings about that in the import specifications that are in the URL that you sent me.
Administrateurs... Tue, 01/05/2010 - 05:58
There's no reference at RDBMS in that document.
I have 200 Shared NAR to create, and hope that RDBMS can achieve that.
Anyone else have an idea ?
Thank you very much.
Correct Answer
Jatin Katyal Thu, 01/07/2010 - 08:20
  • Cisco Employee,
Reasue:
JK
Administrateurs... Thu, 01/07/2010 - 09:28
Thank you very much for your answer.
I'll add them manually instead.  But do you think I'll be able to link them to our user by RDBMS. (not user ou group-level NAR) ?
Thanks again
