ASA5550 automatically rebooted
In our setup we have configured LAN base failover in ASA5550 firewalls in Active/Standby mode.Yesterday automatic failover happened and secondary become active and primary in standby mode.
When we checked the primary firewall we found that it was rebooted.
We have not configured the syslog server so we have left no log with us.Even in show tech support we are not finding any log message and crash file info is also not there.
Can we find out the root cause of firewall reboot without syslog or console log message?
Failover messages:
If we see the “show failover history” output on secondary ASA5550 firewall
we get the following log:
From State                 To State                   Reason
00:23:07 IST Dec 23 2009
Standby Ready              Just Active                HELLO not heard from mate
00:23:08 IST Dec 23 2009
Just Active                Active Drain               HELLO not heard from mate
Active Drain               Active Applying Config     HELLO not heard from mate
Active Applying Config     Active Config Applied      HELLO not heard from mate
Active Config Applied      Active                     HELLO not heard from mate
If we see the “show failover history” output on Primary ASA5550 firewall at 00:23:07
IST Dec 23 2009 there is no log available.
On Primary failover log is available on 00:25:25 IST Dec 23 2009 (After Secondary became Active).
Not Detected               Negotiation                No Error
00:25:32 IST Dec 23 2009
Negotiation                Cold Standby               Detected an Active mate
00:25:34 IST Dec 23 2009
Cold Standby               Sync Config                Detected an Active mate
00:25:46 IST Dec 23 2009
Sync Config                Sync File System           Detected an Active mate
Sync File System           Bulk Sync                  Detected an Active mate
00:25:50 IST Dec 23 2009
Bulk Sync                  Standby Ready              Detected an Active mate
Please help me.
Thanks in advance.
Cheers!!!!!!!!
Vivekanand V
francisco_1
Level 7
Level 7
Hello Vivekanand,
Are the ASAs directly connected for the LAN failover or connected to a switch port?
Also what is the software version?
Vivekanand,
Pls. see if the unit shows any output for "sh crash". If so, pls. open a TAC case and provide them the crash info. along with a sh tech and we will be able to decode the crash and let you know if you are running into an already known issue and suggest a code upgrade accordingly.
If this is a new crash then, we would file a defect to address this.
-KS
