12-30-2009 10:39 PM - edited 03-01-2019 02:16 PM
I want to deploy QOS on two cisco 6509 stacking by vss to limit the transmit rate of some applications.but when i deploy the service-policy on an port-channel interface.it says "MQC features are not supported in output direction for this interface",there is a same problem when i deploy the same policy on an 7609.the ios version information of 6509 is "s72033_rp Software (s72033_rp-ADVENTERPRISEK9_WAN-M), Version 12.2(33)SXI1",the ios version information of 7609 is "c7600rsp72043_rp Software (c7600rsp72043_rp-ADVENTERPRISEK9-M), Version 12.2(33)SRD2",is there a command can solve the problem or should i update the ios ?
12-31-2009 10:29 AM
Hello Jiyuan,
post the policy-map configuration to see what actions are configured on it.
see egress QoS restrictions
You can attach an output policy map to a Layer 3 interface (either a LAN port configured as a Layer 3 interface or a VLAN interface) to apply a policy map to egress traffic.
Note•Output policies do not support microflow policing.
•You cannot apply microflow policing to ARP traffic.
•You cannot set a trust state in an output policy.
Hope to help
Giuseppe
12-31-2009 06:33 PM
Hi Giuseppe,
thanks for you help
police-map xxxx
class-map xxxx
bandwidth percent 30
class-map xxxx
bandwidth percent 20
class class-default
fair-queue
random-detect
an example of my configuration,it seems that the 6509 & 7609 do not support the MQC,how can i slove this problem?
12-31-2009 08:51 PM
thanks for you help,waiting for your reply
--- 10年1月1日,周五, giuslar
发件人: giuslar
主题: New message: "problem when deploy QOS on 6509 & 7609"
收件人: "Jiyuan Gong"
日期: 2010年1月1日,周五,上午2:30
Jiyuan Gong,
A new message was posted in the Discussion thread "problem when deploy QOS on 6509 & 7609":
https://supportforums.cisco.com/message/2011576#2011576
Author : giuslar
Profile : https://supportforums.cisco.com/people/giuslar
Message:
