LMS 3.0 login problem
network_moi
Hi all,
When we try to login to LMS we get the error mention below, (by all user ID created on LMS).
This happened after we upgraded the ciscoview icons recommended on the upgrade window of LMS.
Forbidden
You don't have permission to access /cwhp/cwhp.applications.do on this server.
Additionally, a 403 Forbidden error was encountered while trying to use an ErrorDocument to handle the request.
please advice.
Raj
7 Replies 7
Joe Clarke
Post the output of the pdshow command from the server and screenshots of your Services control panel showing all of the CiscoWorks services.
Please find the attached doc.
Hope this will help us toward solution
Thanks for response,
Raj
x
The only services that should be automatic are :
Ciscoworks Daemon Manager
CWCS rsh/rcp
CWCS syslog
CWCS tftp
put the rest back to manual.
Then restart the Daemon Manager
cheers,
Michel
Done as instructed but no luck.
any other recommendation.
Raj
Well, it seems you started the apache service by yourself (why?), but only the daemon manager should be started.
And normaly after a reboot it would
I notice however that some COM + event system is still starting... not sure what that means (not ciscoworks related)
Anyway looking at the services thing should be ok if you start the deamon manager or reboot the machine
Cheers,
Michel
after reloading the server wait at least 20 mins and then see the services they should start automatically especially deamon manger .... and tehn try to run use the LMS application,,,,
if in services u observed that the deamonmanger is not started automatically then start this.. and wait for atleast 15 mins ....
