Upgrade LMS 3.1 to 3.2
Dec 31st, 2009
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Tableau Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin-top:0cm; mso-para-margin-right:0cm; mso-para-margin-bottom:10.0pt; mso-para-margin-left:0cm; line-height:115%; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin;}
Dear all,
I have installed an LMS 3.1 and I would like to upgrade to LMS 3.2. I would like to know if I have to order a new license or I can reuse the license previously installed.
Thank you in advance.
yjdabear Mon, 01/04/2010 - 13:51
You can re-use the LMS 3.1 license, since 3.2 is not a paid upgrade from it. Matter of fact, the LMS 3.2 upgrade should preserve the existing license during the process, so it should be transparent to you.
juliantowa Thu, 08/19/2010 - 21:32
I can't use license LMS 3.1 on LMS 3.2.
anyone can help me?
