Command SWITCHPORT VOICE VLAN
Dec 31st, 2009
I tried to summarize the behavior of the switch depending on the configuration of the command "switchport voice vlan".
The attached file indicates:
- the way the frame is encapsulated: Tagged or Untagged
- if tagged: the VLAN used in the Tag
- for Voice & Data frames
- for frames sent:
     * from IP phone to Access Switch
     * from Access Switch to IP Phone
     * from Access Switch to Distribution Switch
Any comment on this output would be appreciated.
Navid
