problem facing in cisco 6513 iwth cat os 8.x
The problem i am facing is
1. Not able to access the switch even by console ,telnet,ssh
2. Not able to ping the switch
3. Traffic is passing
4. Able to fetch information via snmp
The sh version is attached
Plz help me in resoving the issue.
milan.kulik
Level 10
Level 10
CPU overload possibly?
Are you able to get the CPU load value via SNMP?
Isn't the switch configured to send Syslog to some sevrer? If yes, are'n there any warnings within the log?
Last chance would be disconnecting the switch from the network totally and try console connection again.
If fails, reboot might help.
BR,
Milan
