Backup CUCM via SFTP using ssh-key
Answered Question
Dec 31st, 2009
I have to backup about 15 CallManagers (mostly CUCM6.1) to an centralized management debian server via SFTP protocol. The problem is the server accepts ssh connections authorized with ssh-keys only, not pass-phrases. This is how its said in internal security policy.
Is there any option how to import into CUCM or generate SSH-KEY inside CUCM (cucm shell, I havent found anything similar in web-gui)? And then paste CUCM's public-key to the server backup user's .ssh/authorized_keys file? So SFTP backup will authenticate via SSH key instead of passhprase?
Does anyone of you confort similar solution?
I would appreciate any kind of idea or help.
Thanks a lot and wish you all happy new year ;-)
Jirka
Correct Answer by Jaime Valencia about 7 years 4 months ago
Not possible, CUCM backup method only uses that simple authentication mechanism of user/pwd configured under SFTP location.
Either set a simple SFTP client or do tape backups.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
Overall Rating: 5 (1 ratings)
Correct Answer
Jaime Valencia Thu, 12/31/2009 - 12:04
  • Cisco Employee,
  • Hall of Fame,
    2011
java
Jiri Solc Sat, 01/02/2010 - 07:41
I'm not happy nor surprised but this still answered my question. Thanks for your clarification java!
Hope some kind of ssh-key backup implementation will be on a roadmap for next releases, CUCM is still linux appliance and this is one of essencial functionality.
J.
Related Content
