OSPF issue
Reza Sharifi Fri, 01/01/2010 - 21:26
Hello Sandeep,
In order for 2 routers to form an adjacency with each other, they have to be in the same area.
For example:
If you have router-1 and router-2 (below) and there is a link between these 2 routers, in order for them to become neighbors, the 2 interfaces must be in the same area.
router-1-------------area0---------------Router-2
Or
router-1-------------area1---------------Router-2
http://72.163.4.161/en/US/tech/tk365/technologies_configuration_example09186a0080094058.shtml
Reza
Muhammad Anser Khan Fri, 01/01/2010 - 22:29
Dear Sandeep,
Two diferrent non-backbone areas are necessary to connect with Area 0 for the communication. Neihgbor relationship can be happen within the same area.
Virtual-Link is the solution to communicate non-backbone areas:
For example:
R1 >> Area 0  R2 >>  Area 1  R3 >>  Area 2  R4
By default Area2 cannot communicate with Area 1 or Area 0.
If we create Virtual-link between R2 and R3. Then Area 2 can communite with Area 1 and Area 0. R3 become an ABR and generates Inter-Area routes to Area 1.
Anser
