Jan 2nd, 2010
Need some reply regarding GETVPN, all GM's connected with KS properly. After few interval of time around 2 hours approx only one GM getting Down. After clearing crypto session, removing crypto map and back it again from interface and its working fine, although this is one of the GM which is closest to KS, other than this all are far away and working fine.
Need some urgent reply. Thanks in advance.
Kent Heide Sat, 01/02/2010 - 22:33
Please provide us with configuration and debugs / show command output from when your issue happens.
Kent Heide Sun, 01/03/2010 - 02:32
Thanks for the configurations although I wish you would have posted them on here instead of using e-mail :-)
As far as your configurations go there is nothing in there that indicates having anything to do with your issue.
When your GM drops off the GETVPN. Is ipsec that barfs or anything else? Please also try to provide a debug crypto gdoi and similar output from when to problem occurs.
