AnyConnect SSL VPN protocol support on the SA500
Jan 2nd, 2010
  • Silver, 250 points or more
I know that the UC520, UC540, UC560, SR520, ASA5505, and many of the ISR models support SSL VPNs. I also know that SPA525G phones and the Cisco IP Communicator softphone can connect to a UC500 over an AnyConnect SSL VPN connection. Currently, the SPA525G requires AnyConnect SSL VPN protocol support in order to be connected via a SSL VPN, whereas Cisco IP Communicator can use Easy VPN or L2TP over IPsec VPN connections. Will there be support for the AnyConnect SSL VPN protocol on the SA500 in the future?
jamccord Tue, 01/12/2010 - 07:05
Anyconnect is not supported by the SA500 series appliance.  I do not believe it is on the roadmap to be implemented.
Related Content
