877 Router Syslog
Jan 3rd, 2010
  • Blue, 1500 points or more
hi experts,
i have a 877 router used for ADSL internet connection. can someone enlighten me regarding the syslog below and how to resolve it? been seeing this for a while and i'm not sure if this is informational log only.
%IP_VFR-4-FRAG_TABLE_OVERFLOW: Dialer0: the fragment table has reached its maximum threshold 16
Ganesh Hariharan Sun, 01/03/2010 - 04:06
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Member's Choice, February 2016
Hi Jhon,
Check out the recommendation and Expalanation
%IP_VFR-4-FRAG_TABLE_OVERFLOW (x1): [chars]: the fragment table has reached
its maximum threshold [dec]
Explanation: The number of datagrams being reassembled at any one time has reached
it maximum  limit.
Recommended Action: Increase the maximum number of datagrams that can be reassembled
by  entering the ip virtual-reassembly max-reassemblies number command, with number
being the  maximum number of datagrams that can be reassembled at any one time.
Hope that clear out your query !!
Ganesh.H
johnlloyd_13 Mon, 01/04/2010 - 05:48
thanks for the reply. for the command:  ip virtual-reassembly max-reassemblies , what is the ideal to be input? do we put the max range for this?
