1200 AP as WG Bridge associate with Linksys AP (or other 3rd party AP)
spollock
I have been able to configure the AP to act as WG Bridge with a Cisco parent AP and it works flawlessly.
I have a Linksys AP in the test environment that is wide open in terms of authentication and it works with any standard client.
However, there is some issue with the 1200 associating with the Linksys in WG Bridge mode.  Below is a debug, is there some reason it wants a Cisco AP as the parent AP?
#deb dot11 dot11Radio 0 trace print uplink
*Mar  1 15:00:24.512: 2EB3608D-0 Uplink: Stop
*Mar  1 15:00:24.512: 2EB360D0-0 Interface down
*Mar  1 15:00:24.520: 2EB382E5-0 Uplink: Wait for driver to stop
*Mar  1 15:00:24.520: 2EB38376-0 Uplink: Enabling active scan
*Mar  1 15:00:24.521: 2EB3838B-0 Uplink: Not busy, scan all channels
*Mar  1 15:00:24.521: 2EB3839E-0 Uplink: Scanning
*Mar  1 15:00:24.523: 2EB38DC3-0 Uplink: checking received beacon / probe response
*Mar  1 15:00:24.523: 2EB38E05-0 Uplink: Rcvd response from 0021.29ea.7d20 channel 6 2303
*Mar  1 15:00:24.556: 2EB40EF3-0 Uplink: checking received beacon / probe response
*Mar  1 15:00:24.560: 2EB41ECE-0 Uplink: no rsnie or ssnie chk
*Mar  1 15:00:24.560: 2EB41EF1-0 Uplink: ssid partridge.net auth open
*Mar  1 15:00:24.560: 2EB41F07-0 Uplink: try 0021.29ea.7d20, enc 0 key 0, priv 0, eap 0
*Mar  1 15:00:24.560: 2EB41F2B-0 Uplink: Authenticating
*Mar  1 15:00:24.566: 2EB4397F-0 Uplink: Associating
*Mar  1 15:00:24.568: 2EB4409C-0 Uplink: No Cisco parent  <<--------------------------------------------------------- {indicates is must be a CISCO AP???}
*Mar  1 15:00:29.566: 2F00820D-0 Uplink: Lost AP, Associate response timeout
*Mar  1 15:00:29.567: 2F00823A-0 Uplink: Reject for 0 seconds
*Mar  1 15:00:29.567: 2F008250-0 Uplink: Scanning
*Mar  1 15:00:29.569: 2F008C55-0 Uplink: checking received beacon / probe response
Cisco IOS Software, C1200 Software (C1200-K9W7-M), Version 12.3(8)JA2, RELEASE SOFTWARE (fc1)
no aaa new-model
dot11 ssid partridge.net
   authentication open
dot11 network-map
username cisco password 7 072C285F4D06
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
ssid partridge.net
speed basic-1.0 2.0 5.5 6.0 9.0 11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role workgroup-bridge
bridge-group 1
bridge-group 1 spanning-disabled
ANDREW WIGHTMAN
Hi there,
I have a 1242 working as a WGB on a non-Cisco WLAN. It is working with Aruba. You need to make sure you are running at least version 12.4 for it to work. From what I can see it is very limited - I can only get one client connecting to the Ethernet port :-(
You basically have to use the command below to turn on Universal mode - the mac address is the mac address of your fixed client.
station-role workgroup-bridge universal aaaa.bbbb.cccc
