HWIC-D-9ESW Features Support
Jan 3rd, 2010
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"טבלה רגילה"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:Arial; mso-bidi-theme-font:minor-bidi;} Hi,
Does anybody knows if I can use the following features on the HWIC-D-9ESW card:
1.Port Security (I saw something that refer only to mac limiting…)
2.EEM
Is there any limitations running these features on that kind of card ?
Giuseppe Larosa Sun, 01/03/2010 - 08:29
Hello Ran,
features restrictions are listed in 12.4T IOS LAN switching configuration guide
http://www.cisco.com/en/US/docs/ios/lanswitch/configuration/guide/lsw_hwic_ethsw_ic_ps6441_TSD_Products_Configuration_Guide_Chapter.html#wp1043334
and specifically for port security:
      There is a limit of 200 secure MAC addresses per module that can be supported by an EtherSwitch HWIC.
Maximum traffic for a secure MAC address is 8 Mb/s.
EEM is not mentioned in this document
You can find help for EEM in network management forum.
Hope to help
Giuseppe
