ASA 5540 DHCP server - how to serve more than 255 addresses
Jan 3rd, 2010
I have an internal lan set up as a /21.  I'd like to serve dhcp to most all of them.  The pool address seems to be limited to 255 clients.  Is there any way around this?
Thanks,  Roger
YANGCCIE4 Sun, 01/03/2010 - 08:36
If I understood your posting right,
you can change the subnet number to add the more host addresses in one subnet.
/24 subnet includes 253 hosts.
/23 subnet includes 510 hosts.
so you can change the dhcp server settings to realize this proposal.
hope it helps
Yang
rwiechman Sun, 01/03/2010 - 08:48
The internal address is already assigned a /21 (255.255.248.0 mask) which would allow 2046 hosts.  (x.x.8.1-x.x.15.254 for instance).
However, at least using ASDM, it complains about larger than 255 if I use the range x.x.8.30 - x.x.15.254.
I have not tried using the command line to see if it will take multiple address range statements, but I suspect it wont.
Roger
vilaxmi Sun, 01/03/2010 - 13:59
One solution to your problem could be to create a second  INSIDE interface  (security-level = 100) on the ASA. Then you can make the new iterfcae as DHCP server in order to serve clients. Please keep in mind that for access from inside (behind old inside interface) to inside (behind new inside interface) would need additional U turn NAT configurations on ASA.
Vijaya
YANGCCIE4 Sun, 01/03/2010 - 08:37
so you can change the dhcp server settings to realize this proposal.  ---- in the dhcp pool xx  + options.
hope it helps
Yang
J_Vansen_S Thu, 04/01/2010 - 20:30
"so you can change the dhcp server settings to realize this proposal.  ---- in the dhcp pool xx  + options."
that does not seem to work.
Apprarently the ASA's command takes it in the format
dhcpd address 192.168.8.10-192.168.8.100 *interface*
dhcpd enable *interface*
no way to configure it as /23? /22?
Please advise
JORGE RODRIGUEZ Fri, 04/02/2010 - 22:14
Roger,  as far as I know DHCP feature  has a limitation of address pool per interface  , see guidelines, http://www.cisco.com/en/US/docs/security/asa/asa80/command/reference/d2.html#wp1904997
It is  more pratical to used a local DHCP server  for your requirements, if you have Windows AD server DHCP services is free, or you may find 3rd party freeware DHCP servers software out here.  You may also look at dhcp relay feature , see same link above but you will stilll need stand alone DHCP server for that .
Related Content
