Call Manager - Goes Unresponsive for 15 minutes
Jan 3rd, 2010
Hello All,
            We have a Call Manager Linux server running  This is the publisher and recently the server hs gone unrespsive for 15 minutes at a time.  I have recently enabled link status traps on the switch to see if that is the issue.  What can I look at on the call manager side?  I was looking through the traces for specific traces to enable.  I'am collecting core dump files in RTMT.  Anyone know of any bugs in this version of Call Manager that could be causing this?  thanks
Hi Jason,
I had similar issues, does it only happen on the publisher ?  When i experienced the problem restarting the tomcat service cured it. Something to do with it taking all the memory. Try looking through the readme's for the latest version of ccm 5.1.x you will probably find loads of issues which were fixed in the latest version. I upgrade my cluster to the latest ES at the time and this cured the problem.
Hope this helps
