10 Gig Trunk Port
Jan 3rd, 2010
I'm setting up two 3750E switches on a bench prior to installing them  - with a ten Gig port trunk port between them. I am running PVST and have pretty standard switch configuration.   Show span indicates that all my vlans are forwarding between the ports but the packet rate keeps increasing as if its in a loop.  Must be something obvious but can't find it - is there anything special you have to do to those ten GIG Modules to get them to work.
# interface ten gig 1/0/2
# sw trunk enc dot1q
# sw mode trunk
# sw nonegotiate
viyuan700 Mon, 01/04/2010 - 06:19
  • Silver, 250 points or more
If both ports are up then you can check if there is problem with your cables . Possible too much BER because of bad cable or card.
What type  of cards you have (short distance/long distance)
JSCHWENG_2 Mon, 01/04/2010 - 06:51
ok thanks - I don't see any errors on the ports though.  Its only broadcast packets going back and forth.  The packet rate keeps incr
easing until I shut the port down.  I'm using X2-10GB-LR= modules.
viyuan700 Mon, 01/04/2010 - 13:48
pardon me. I thought you are saying that packets are dropping but you are talking about STP loop.
As mentioned in other post, check  if this link creating STP loop because of UDLD ?  Maybe one of your cable not working or some other reason.
Though in LR you dont need an attenuator but check the power levels at both sides.Are they within receiver sensitivity? as you must be  connecting back to back just with patch cables.
Leo Laohoo Mon, 01/04/2010 - 12:51
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
And you are using SM patch cables (duplex) right?
