What happen with Router 1841, It's disappear promt to configure.
Jan 3rd, 2010
Hi All,
          I have a problem with Router 1841 on software version 12.4(13r) T, After reboot system I cannot access to CLI.
The attached file is capture screen during turn on my device.
Thank you.
Leo Laohoo Sun, 01/03/2010 - 20:04
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
Sounds like an IOS bug.  Have you considered upgrading from 12.3(8)YG4 to the 12.4 version IOS?
CiscoSCC Multilink Sun, 01/03/2010 - 20:17
Thankyou for your reply.
No, I don't have upgrade software , just "reload" command then found problem.
Leo Laohoo Mon, 01/04/2010 - 12:37
  • Hall of Fame,
    2017 LAN, Wireless
Try removing the modules you may have and reload the router to see if the router crashes again.  If not, then I recommend that you upgrade your IOS.
Richard Burts Mon, 01/04/2010 - 14:08
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
The original poser describes the attached file as a screen capture during the problem. But what I get in the attached file is not a screen shot but is part of a crashinfo file, which is not at all helpful in finding problems with the prompt. A screen caprue would be much more helpful.
Without a screen capture and with the minimal description in the orininal post I have difficulty determining whether the problem might be:
- problems in accessing the user mode prompt.
- can access user mode but has problems in accessing enable mode.
-can access enable mode but has problems in accessing config mode.
- could it be something else?
some clarification from the original poster would be helpful.
Rick
CiscoSCC Multilink Mon, 01/04/2010 - 18:54
Thank you anybody,
     Right Now, after upgrade to new software the problem has been resolve.
Leo Laohoo Mon, 01/04/2010 - 19:01
  • Hall of Fame,
    2017 LAN, Wireless
Can you mark this post as "Answered"?
