SPA3102: NAT Mapping Enable: registration fails
Jan 3rd, 2010
Hi!
I have a problem with NAT and enabling NAT Mapping succesfully on the SPA3102 with firmware 5.1.10(GW).
I have these set in the Voice/SIP tab:
• Handle VIA received: yes
• Handle VIA rport: yes
• Insert VIA received: yes
• Insert VIA rport: yes
• Substitute VIA Addr: yes
• Send Resp To Src Port: yes
• STUN Enable: Choose yes.
• STUN Server: stun.freeswitch.org
And I have 'Nat Mapping Enabled' under Line 1 tab.  I see the external IP address in the Status page.
Below is what I see from the syslog.  The second register (at time 17:41:31) is never received at the SIP server end (a FreeSwitch server).
Jan  4 17:41:20 92.xx.xx.xx REGISTER sip:124.xxx.xxx.xxx:442 SIP/2.0  Via: SIP/2.0/TLS 192.168.1.3:56886;branch=z9hG4bK-1a90facc;rport  From: 2001 <sip:[email protected]:442>;tag=c7ba46a8b33b5deco0  To: 2001 <sip:[email protected]:442>  Call-ID: [email protected] CSeq: 10475 REGISTER  Max-Forwards: 70  Contact: 2001 <sip:[email protected]:56886;transport=tls>;expires=600  User-Agent: Linksys/SPA3102-5.1.10(GW)  Content-Length: 0  Allow: ACK, BYE, CANCEL, INFO, INVITE, NOTIFY, OPTIONS, REFER  Supported: x-sipura, replaces
Jan  4 17:41:21 92.xx.xx.xx [0]<<124.xxx.xxx.xxx:442(672)
Jan  4 17:41:21 92.xx.xx.xx SIP/2.0 401 Unauthorized  Via: SIP/2.0/TLS 192.168.1.3:56886;branch=z9hG4bK-1a90facc;rport=56886;received=92.xx.xx.xx  From: 2001 <sip:[email protected]:442>;tag=c7ba46a8b33b5deco0  To: 2001 <sip:[email protected]:442>;tag=HtDQpjj81jvZm  Call-ID: [email protected] CSeq: 10475 REGISTER  User-Agent: FreeSWITCH-mod_sofia/1.0.trunk-15490  Allow: INVITE, ACK, BYE, CANCEL, OPTIONS, MESSAGE, UPDATE, INFO, REGISTER, REFER, NOTIFY, PUBLISH, SUBSCRIBE  Supported: timer, precondition, path, replaces  WWW-Authenticate: Digest realm="124.xxx.xxx.xxx", nonce="2b30fca4-f8fc-11de-88a5-dbc3ffce4ce8", algorithm=MD5, qop="auth"  Content-Length: 0
Jan  4 17:41:21 92.xx.xx.xx [0]ExtIpChanged: 92.xx.xx.xx
Jan  4 17:41:21 92.xx.xx.xx [56886]STUN trying 0
Jan  4 17:41:21 92.xx.xx.xx [56886]STUN trying 1
Jan  4 17:41:22 92.xx.xx.xx [56886]STUN trying 2
Jan  4 17:41:22 92.xx.xx.xx [56886]STUN trying 3
Jan  4 17:41:23 92.xx.xx.xx [56886]STUN trying 4
Jan  4 17:41:24 92.xx.xx.xx [56886]STUN trying 5
Jan  4 17:41:26 92.xx.xx.xx [56886]STUN trying 6
Jan  4 17:41:28 92.xx.xx.xx [56886]STUN trying 7
Jan  4 17:41:29 92.xx.xx.xx [56886]STUN trying 8
Jan  4 17:41:31 92.xx.xx.xx [0]->124.xxx.xxx.xxx:442(776)
Jan  4 17:41:31 92.xx.xx.xx REGISTER sip:124.xxx.xxx.xxx:442 SIP/2.0  Via: SIP/2.0/TLS 92.xx.xx.xx:56886;branch=z9hG4bK-78f89705;rport  From: 2001 <sip:[email protected]:442>;tag=c7ba46a8b33b5deco0  To: 2001 <sip:[email protected]:442>  Call-ID: [email protected] CSeq: 10476 REGISTER  Max-Forwards: 70  Authorization: Digest username="2001",realm="124.xxx.xxx.xxx",nonce="2b30fca4-f8fc-11de-88a5-dbc3ffce4ce8",uri="sip:124.xxx.xxx.xxx:442",algorithm=MD5,response="633bcd697072e62c8c3aadfdca57815a",qop=auth,nc=00000001,cnonce="b9559c13"  Contact: 2001 <sip:[email protected]:56886;transport=tls>;expires=600  User-Agent: Linksys/SPA3102-5.1.10(GW)  Content-Length: 0  Allow: ACK, BYE, CANCEL, INFO, INVITE, NOTIFY, OPTIONS, REFER  Supported: x-sipura, replaces
Jan  4 17:41:41 92.xx.xx.xx [0]SIP/TCP Idle
Jan  4 17:42:21 92.xx.xx.xx [0]SIP/TCP ServerNoService
Help appreciated.
Alberto Montilla Mon, 01/04/2010 - 03:39
Dear Sir;
Did you check with the ISTP about the specific mapping required? If not I suggest you only set the following mapping to yes, and leave the others to no:
• Handle VIA rport: NO
• Insert VIA received: NO
• Insert VIA rport: NO
• Substitute VIA Addr: YES
• Send Resp To Src Port: NO
Alberto
mcampbellsmith Mon, 01/04/2010 - 04:59
EDITED!
The problem seems to only appear with TCP or TLS is enabled as the transport.
I have tried with the stanard port 5061 and I get the same error.  The router is setup to forward both TCP and UDP packets
I control the FreeSwitch box that the SPA should be registered to, so I can do any changes you suggest!  Any further help appreciated.
mcampbellsmith Tue, 01/05/2010 - 03:12
More checking at it seem to be a STUN issue somehow.  When I hard code in the external IP address and have NAT Mapping Enabled, everything is great.
When I have STUN, it is not.
Below is the syslog from the SPA3102:
THIS WORKS (Ext IP address hardcoded)
Jan  5 21:18:17 92.xx.xx.xx [0]->124.xxx.xxx.xxx:442(544)
Jan  5 21:18:17 92.xx.xx.xx REGISTER sip:myddns.dydns.org:442 SIP/2.0
Via: SIP/2.0/TLS 92.xx.xx.xx:5069;branch=
z9hG4bK-7b7ebbf9  From: 2001
<sip:[email protected]:442>;tag=b69c38c549e24c42o0  To: 2001
[email protected]  CSeq: 44358 REGISTER  Max-Forwards: 70
Contact: 2001 [email protected]:5069;transport=tls>;expires=600
x-sipura, replaces
Jan  5 21:18:17 92.xx.xx.xx [0]<<124.xxx.xxx.xxx:442(658)
Jan  5 21:18:17 92.xx.xx.xx SIP/2.0 401 Unauthorized  Via: SIP/2.0/TLS
92.xx.xx.xx:5069;branch=z9hG4bK-7b7ebbf9;rport=5069  From: 2001
<sip:[email protected]:442>;tag=Bav1HeBr3jm3B  Call-ID:
[email protected]  CSeq: 44358 REGISTER  User-Agent:
FreeSWITCH-mod_sofia/1.0.trunk-16131  Allow: INVITE, ACK, BYE, CANCEL,
WWW-Authenticate: Digest realm="myddns.dydns.org",
nonce="a4128380-f9e3-11de-99eb-53ce5686ac9a", algorithm=MD5,
Jan  5 21:18:17 92.xx.xx.xx [0]->124.xxx.xxx.xxx:442(782)
Via: SIP/2.0/TLS 92.xx.xx.xx:5069;branch=z9hG4bK-18f00822  From: 2001
[email protected]  CSeq: 44359 REGISTER  Max-Forwards: 70
username="2001",realm="myddns.dydns.org",nonce="a4128380-f9e3-11de-99eb-53ce5686ac9a",uri="sip:myddns.dydns.org:442",algorithm=MD5,response="324ee93184ae202be4a209f5a9255229",qop=auth,nc=00000001,cnonce="804844b"
x-sipura, replaces
Jan  5 21:18:18 92.xx.xx.xx SIP/2.0 200 OK ....
THIS DOES NOT WORK
Jan  5 22:05:48 92.xxx.xxx.xxx REGISTER sip:myddns.dydns.org:442
SIP/2.0  Via: SIP/2.0/TLS 192.168.1.3:5070;branch=z9hG4bK-faf8477a
From: 2001 <sip:[email protected]:442>;tag=b065057e3ed0befdo0  To:
[email protected]  CSeq: 44435 REGISTER  Max-Forwards: 70
Contact: 2001 ;expires=600
x-sipura, replaces
Jan  5 22:05:48 92.xxx.xxx.xxx SIP/2.0 401 Unauthorized  Via:
SIP/2.0/TLS 192.168.1.3:5070;branch=z9hG4bK-faf8477a;received=92.xxx.xxx.xxx;rport=5070
To: 2001 <sip:[email protected]:442>;tag=N51jvyeca9Umj  Call-ID:
[email protected]  CSeq: 44435 REGISTER  User-Agent:
nonce="476097b0-f9ea-11de-99fd-53ce5686ac9a", algorithm=MD5,
Jan  5 22:05:58 92.xxx.xxx.xxx [0]->124.xxx.xxx.xxx:442(783)
Jan  5 22:05:58 92.xxx.xxx.xxx REGISTER sip:myddns.dydns.org:442
SIP/2.0  Via: SIP/2.0/TLS 92.xxx.xxx.xxx:5070;branch=z9hG4bK-bfc992b3
[email protected]  CSeq: 44436 REGISTER  Max-Forwards: 70
username="2001",realm="myddns.dydns.org",nonce="476097b0-f9ea-11de-99fd-53ce5686ac9a",uri="sip:myddns.dydns.org:442",algorithm=MD5,response="466ea78ac2ccddca991a5c3d4d021bed",qop=auth,nc=00000001,cnonce="ebd80711"
x-sipura, replaces
This is all I see
The difference was a hard coded external IP address in the first session that worked.  However I can't have it set like this as the IP address is not static.
The second REGISTER in the Not Working session seems to be ignored by FreeSwitch (I don't see it in the logs of FS either).   Is there something in this Register that causes FS to ignore it?  Thanks
EDIT: TURNING OFF STUN AND IT WORKS (with NAT Mapping Enabled) .... How can the SPA3102 determine its external IP address if the stun server option is switched off?  I see the external IP address int eh status page - how is this determined and why does this work?
Alberto Montilla Tue, 01/05/2010 - 06:32
Dear Sir;
The only difference is that in non working case the Contact info continues pointing to the private IP address 192.xx.xx.xx and that's wrong since this address is not routable.
The issue could be that STUN is not working properly. Do you know if your router has symmetric NAT? STUN does not work with symmetric NAT routers.
Regards;
Alberto
mcampbellsmith Tue, 01/05/2010 - 12:41
Thanks Alberto.
Do you know how I can check if my router is symetric or not?
Also, If I TURN OFF STUN IT WORKS (with NAT Mapping Enabled) .... How can the SPA3102 determine its external IP address if the stun server option is switched off?  I see the external IP address int eh status page - how is this determined and why does this work?
Alberto Montilla Thu, 02/18/2010 - 02:01
Dear Carlos;
Let me escalate this to engineering. I'll let you know the outcome.
Alberto
mcampbellsmith Thu, 02/18/2010 - 02:46
Hi Alberto,
Please make sure that SP3102 issue is escalated as well as the SPA9x2.  I still have issues with this on my SPA firmware (the latest PA3102-5.1.10(GW) )
Thanks!
reddragon24 Mon, 03/08/2010 - 04:06
the sip server does not recieve the packets due to STUN. BTW why are you using STUN: " dont want to get voice relay from the server" if yes, try this:
Disable NAT Mapping , enable Keep alive and check the RTP packets 99.9% voice will connect directly not via server. And, Stun is only usefull if using very cheap router but if you are using linksys guranteed will not face any problem.
If you are behid double NAT ( behind two or more routers) make sure routers are runing in bridge mode.
cesterlizi Wed, 03/17/2010 - 07:03
Hi Alberto
Do you have any news for this issue from the engineering team  ?
Thanks & Regards
Carlos
Alberto Montilla Wed, 03/17/2010 - 15:11
Dear Sir;
I checked with engineering and actually STUN does work only with UDP as defined in the RFC.
Do you use a static IP address? If so I think you can disable STUN and still get mapping ok.
Alberto
cesterlizi Tue, 02/16/2010 - 14:12
Hi Alberto
We have the same issue with SPA9x2, firmwares 5.2.8 and 6.1.5(a)
We are using TCP or TLS as  transport and if we set
NAT Mapping Enable[1] = yes
STUN Enable  = yes
STUN Server = mystun.xxxx.com
the SPA9x2 fails to REGISTER
I am attaching 3 captures (take a look with wireshark).
1) SIP UDP transport with NAT Mapping Enable=yes -> REGISTER OK, STUN reachable and IP mapped
2) SIP TCP transport with  NAT Mapping Enable=yes -> REGISTER NOK, STUN not reachable and IP not mapped
3) SIP TCP transport with  NAT Mapping Enable=no -> REGISTER OK but IP is not mapped
192.168.1.52 SPA9x2
192.168.1.61 proxy
The problem seems to be the combination of TCP/TLS + STUN  with NAT Mapping Enable
Thanks & Regards
Carlos
