01-03-2010 11:34 PM
Hi all,
Can anyone tell me if it is possible to have the Hardware Inventory report within LMS3.1 provide details of multiple Cat3750 switches when they are stacked together using a Stackwise solution? - At present, if I run a hardware inventory report, only one of the 3750 switches (usually the master) in a stack has it's details included in the report, whereas I would like to see details of all the switches in the stack.
Many thanks in advance,
Rowan
Solved! Go to Solution.
01-04-2010 08:44 AM
Run the Detailed Device Report, and you will see each member chassis under the Chassis Information section.
01-04-2010 08:44 AM
01-04-2010 04:49 PM
Hi Joe,
Many thanks for this response, I was hoping that there would be a report as concise at the hardware inventory which also contained the chassis serial numbers for other switch members in the same stack - but without all the additional information included in the detailed device report.
Best regards,
Rowan.
01-04-2010 05:42 PM
If chassis serial number is all you want, create an inventory custom report with the ruleset:
Chassis:Chassis Serial Number:equals:All
Then run that report for your 3750 stacks, and that will show you the chassis serial number for every stack member without any other details to muddy the report.
