Cisco SA540 Routing Setup
Jan 4th, 2010
To whom it may concern:
I am trying to setup a Cisco SA540 with various routes; my problem is that via GUI I am not allowed to define a network as a destination but only a host e.g. is fine but not
Also, the routes that I am trying to definew manually do not appear in the diagnostics screen. Can anyone advise if this is a bug or not? I am running firmware version 1.0.39
Steven Smith Mon, 01/04/2010 - 07:39
In 1.0.39, there is a bug with adding static routes.  If you add a host on a network, the route will work correctly.  This should be addressed in the next firmware revision.  I will also ask about the networks not showing up on the diagnostics page.  They are working for me and do not show up there as well.
jonathan_vella Mon, 01/04/2010 - 07:46
Hi Steven,
thanks for your reply. Any idea when the new firmware will be available?
Steven Smith Mon, 01/04/2010 - 08:12
Hopefully by the end of January, but dates are tentative and can change.
Related Content
