HSRP configure in core
Jan 4th, 2010
using 4506e sup eng 6-E as core redandency with distribution L3 switch, L3 Switch is dedandency with L2 Access switch campas network. configured total 22 number of vlan (vlan 1 -22)
can I use different group for different vlan?
how hsrp get heartbit from core1 to core2?
Giuseppe Larosa Mon, 01/04/2010 - 04:34
Hello Dipak,
you can use different group numbers or you can reuse the same group numbers because multilayer switches allow for this.
On routers you need to use different group number in different vlan subinterface.
you need a L2 trunk allowing all vlans of interest between the two core switches or the HSRP hellos will go via the access layer switches.
if you have L2 access layer switches a L2 trunk made of an etherchannel between the two cores can be a a good choice.
Hope to help
Giuseppe
