LMS 3.2: Running CSCOpx processes
Jan 4th, 2010
  • Gold, 750 points or more
After a Device Package update, I see the following procs left running:
    root  8268     1  24 15:39:15 ?           1:11 /opt/CSCOpx/objects/dmgt/dmgtd.sol
    root 10304  2006   0 15:51:01 ?           0:00 /opt/CSCOpx/bin/in.tftpd -s /tftpboot
casuser 23883     1   0   Dec 23 ?           0:10 /opt/vgi/csco/CSCOpx/objects/wfengine/program/PolicyScheduler
casuser 23878     1   0   Dec 23 ?           0:05 /opt/vgi/csco/CSCOpx/objects/wfengine/program/DataStore
casuser 23880     1   0   Dec 23 ?           0:12 /opt/vgi/csco/CSCOpx/objects/wfengine/program/GGLogger
casuser 23881     1   0   Dec 23 ?           0:05 /opt/vgi/csco/CSCOpx/objects/wfengine/program/GGProxy
casuser 23889     1   0   Dec 23 ?           0:04 /opt/vgi/csco/CSCOpx/objects/wfengine/program/GGHelper
casuser 23879     1   0   Dec 23 ?           0:06 /opt/vgi/csco/CSCOpx/objects/wfengine/program/GGScript
casuser 23882     1   0   Dec 23 ?           1:25 /opt/vgi/csco/CSCOpx/objects/wfengine/program/OpsBREngine
casuser 11683     1  24 15:59:39 ?           1:32 /opt/vgi/csco/CSCOpx/lib/jre/bin/java -classpath /opt/vgi/csco/CSCOpx/lib/class
I let it stand for 3-5 mins, but didn't see any more procs coming back up, so I manually restarted dmgtd. My question here is: Does it really take that "long" to bring everything but up, or was I not patient enough?
After dmgtd stop, I still see some CSCOpx procs running:
casuser 11683     1  25 15:59:39 ?           4:11 /opt/vgi/csco/CSCOpx/lib/jre/bin/java -classpath /opt/vgi/csco/CSCOpx/lib/class
Is that "normal"? I thought in earlier versions there's none left "standing" after stopping dmgtd.
Joe Clarke Mon, 01/04/2010 - 13:23
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Doing what you did is bad.  It will take a long time for all the processes to come back after a package update.  The reason for that, is first dmgtd will shutdown each process (dmgtd itself will stay running).  Then, it will install the packages, then proceed to restart each process.  The whole thing can take 30 minutes.  By restarting processes after five minutes, you may have corrupted your package maps and/or repositories.
yjdabear Mon, 01/04/2010 - 13:25
Doh! Is there any way to "verify" whether I got away with it unscathed or not?
yjdabear Mon, 01/04/2010 - 13:29
I'm running Device Pkg update again. I get prompted for a single new pkg being available.
1.Cat3560DevicePackageCiscoView5.06.0Cat3560.cv50.v6-0.readme NANA
Here'st the Event Log of the previous Device Pkg update:
Number of Packages Selected for Install : 57
For Product(s) : CiscoWorks Common Services,LMS Portal,CiscoWorks Assistant,CiscoView,Resource Manager Essentials,Campus Manager,Internetwork Performance Monitor
Install Invoked by user : admin
The Package(s) Selected for Install :
DeviceData, Mdf, Cat2350, Cat2960, Cat2975, Cat3560, miniRMON, PoE, CVCrossLaunch, Cat6000IOS, CVGenericPackage, CBS31x0, MWR, Rtr10000, Rtr3900, Rtr2900, Rtr1900, Rtr1800, NGMARShare, Rtr3800, Rtr7000, Rtr800, Routershare, SwitchAddlets, Cat2960, Cat3560, Cat3750, Cat4000IOS, CatGL3, IAD2400, LibCommon, LibDcma, LibInventory, LibNetconfig, LibSwim, Rtr3200, RtrUBR, SharedDcmaIOS, SharedDcmaSS, SharedInventoryCatIOS, SharedInventoryMDS, SharedInventoryRouter, SharedNetconfigIOS, SharedNetconfigSS, SharedNetshowIOS, SharedNetshowSS, SharedSwim2900XL, Rtr3900, Rtr1900, Rtr2900, Rtr800, SharedSwimIOS, CE500, ASR, Nexus, SharedSwimMDS9000, CMDeviceUpdates
Successfully installed packages (2):
DeviceData(1.6) ,Mdf(1.36)
Installation Completed for : CiscoWorks Common Services
No package(s) to install for : LMS Portal
No package(s) to install for : CiscoWorks Assistant
WARNING :  Cat3750(8.0):Version 8.0 already installed
WARNING :  CE500(5.0):Version 5.0 already installed
WARNING :  IAD2400(7.0):Version 7.0 already installed
WARNING :  Cat4000IOS(16.0):Version 16.0 already installed
Successfully installed packages (21):
SwitchAddlets(1.26) ,Rtr3800(9.0) ,Rtr10000(10.2) ,NGMARShare(1.11) ,CVCrossLaunch(2.2) ,Rtr7000(22.0) ,Cat2960(6.0) ,Rtr1900(1.0) ,MWR(1.0) ,miniRMON(3.3) ,PoE(1.3) ,CVGenericPackage(1.3) ,Rtr2900(2.0) ,Cat2975(1.0) ,Cat2350(1.0) ,Rtr3900(1.1) ,Rtr800(14.0) ,CBS31x0(3.0) ,Routershare(1.2) ,Cat6000IOS(30.2) ,Rtr1800(8.0)
Installation Completed for : CiscoView
Successfully installed packages (32):
SharedInventoryRouter(2.5.2) ,SharedSwim2900XL(2.2.2) ,Cat3750(6.2) ,LibCommon(2.4.2) ,RtrUBR(1.3) ,SharedInventoryMDS(1.5.1) ,CE500(6.1) ,SharedInventoryCatIOS(2.3.2) ,SharedSwimMDS9000(1.6.2) ,SharedNetshowIOS(2.2.3) ,Cat3560(7.3) ,LibNetconfig(2.2.2) ,Cat2960(6.3) ,SharedDcmaIOS(2.4.3) ,Rtr1900(2.2) ,SharedNetconfigSS(1.2.1) ,ASR(2.1) ,SharedDcmaSS(2.2.1) ,IAD2400(1.3) ,Cat4000IOS(7.2) ,LibInventory(3.1.4) ,LibSwim(2.5.3) ,Rtr2900(1.1) ,SharedNetconfigIOS(2.3.2) ,CatGL3(5.2) ,Rtr3900(1.0) ,Rtr800(6.3) ,SharedNetshowSS(1.1.1) ,SharedSwimIOS(2.5.3) ,LibDcma(2.3.2) ,Rtr3200(5.1) ,Nexus(2.3)
Installation Completed for : Resource Manager Essentials
Successfully installed packages (1):
CMDeviceUpdates(6.0)
Installation Completed for : Campus Manager
No package(s) to install for : Internetwork Performance Monitor
Does it mean no harm done to the Device Pkg map?
Joe Clarke Mon, 01/04/2010 - 13:34
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
This means the package map is okay.  Corruption there usually brings up 500 server errors.  As for validating the RME package repository, you should have 330 packages on an up-to-date 4.3.1 server.
yjdabear Mon, 01/04/2010 - 13:46
That's great news: I do have 330 RME pkgs, and 746 RME device types to match.
So I let it come back autonomously this time. Should I be concerned about some of the downed or failed processes according to the current proc status?
1.1395Administrator has shut down this server000N/ANot applicable
2.ANIDbEngineProgram started - No mgt msgs received187670001/04/10 16:37:53Not applicable
3.ANIServerRunning with busy flag set193770001/04/10 16:40:49Not applicable
4.CampusOGSServerAdministrator has shut down this server00001/04/10 16:11:3001/04/10 16:32:15
5.ChangeAuditAdministrator has shut down this server0-113001/04/10 16:11:5901/04/10 16:31:56
6.CmfDbEngineProgram started - No mgt msgs received193810001/04/10 16:40:54Not applicable
7.CmfDbMonitorFailed to run00601/04/10 16:11:1401/04/10 16:40:58
8.CMFOGSServerProgram started - No mgt msgs received194600001/04/10 16:41:10Not applicable
9.ConfigMgmtServerAdministrator has shut down this server0-113001/04/10 16:11:3901/04/10 16:32:05
10.CSDiscoveryAdministrator has shut down this server000N/ANot applicable
11.CSRegistryServerRunning normally188090001/04/10 16:38:02Not applicable
12.CTMJrmServerRunning normally195720001/04/10 16:41:31Not applicable
13.CWAPublisherProgram started - No mgt msgs received196520001/04/10 16:41:50Not applicable
14.DCRDevicePollAdministrator has shut down this server000N/ANot applicable
15.DCRServerRunning normally194000001/04/10 16:40:58Not applicable
16.diskWatcherRunning normally196300001/04/10 16:41:41Not applicable
17.EDSRunning normally192930001/04/10 16:40:22Not applicable
18.EDS-GCFAdministrator has shut down this server00001/04/10 16:11:3901/04/10 16:33:46
19.ESSProgram started - No mgt msgs received186730001/04/10 16:37:35Not applicable
20.EssentialsDMRunning normally194680001/04/10 16:41:15Not applicable
21.EssMonitorRunning normally186770001/04/10 16:37:39Not applicable
22.EventFrameworkProgram started - No mgt msgs received187080001/04/10 16:37:45Not applicable
23.FDRewinderAdministrator has shut down this server000N/ANot applicable
24.ICServerAdministrator has shut down this server00001/04/10 16:11:3901/04/10 16:32:07
25.IpmDbEngineProgram started - No mgt msgs received187270001/04/10 16:37:49Not applicable
26.IPMOGSServerAdministrator has shut down this server0-113001/04/10 16:12:0301/04/10 16:31:52
27.IPMProcessProgram started - No mgt msgs received195950001/04/10 16:41:37Not applicable
28.jrmRunning normally195380001/04/10 16:41:24Not applicable
29.LicenseServerProgram started - No mgt msgs received192420001/04/10 16:40:13Not applicable
30.MACUHICRunning normally187800001/04/10 16:37:57Not applicable
31.NameServerProgram started - No mgt msgs received192460001/04/10 16:40:14Not applicable
32.NameServiceMonitorRunning normally192870001/04/10 16:40:18Not applicable
33.OpsxmlDbEngineProgram started - No mgt msgs received187960001/04/10 16:37:58Not applicable
34.OpsXMLRuntimeProgram started - No mgt msgs received196410001/04/10 16:41:46Not applicable
35.PMCOGSServerAdministrator has shut down this server00001/04/10 16:11:3901/04/10 16:32:09
36.ProcSysBusProgram started - No mgt msgs received196340001/04/10 16:41:41Not applicable
37.RMEDbEngineProgram started - No mgt msgs received187130001/04/10 16:37:45Not applicable
38.RMEOGSServerProgram started - No mgt msgs received194780001/04/10 16:41:19Not applicable
39.SyslogAnalyzerAdministrator has shut down this server0-113001/04/10 16:11:5901/04/10 16:31:55
40.SyslogCollectorProgram started - No mgt msgs received187100001/04/10 16:37:45Not applicable
41.TomcatMonitorRunning normally188640001/04/10 16:38:07Not applicable
42.UTLITERunning normally187840001/04/10 16:37:58Not applicable
43.UTMajorAcquisitionAdministrator has shut down this server000N/ANot applicable
44.UTManagerAdministrator has shut down this server02001/04/10 16:11:3901/04/10 16:32:04
45.VNMServerProgram started - No mgt msgs received187920001/04/10 16:37:58Not applicable
46.WlseUHICRunning normally187880001/04/10 16:37:58Not applicable
Joe Clarke Mon, 01/04/2010 - 13:49
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Did you run the installation again?  If so, and if PSU is still performing the installation and daemon restart, then no.  Else, you do have some problems.  There appears to be some issues with the cmf database as well as other processes.  If these processes don't come back up automatically in about 30 minutes, then you definitely have a problem.
yjdabear Tue, 01/05/2010 - 06:29
I simply let Device Pkg Update install the CiscoView Cat3560 pkg pictured earlier. It's then left unattended. The reason I developed the inclination to manually intervene at all was because I had a similar issue with LMS procs (*OGS* ones) not coming back properly in LMS 3.1 on my production box (alluded to in this thread: https://supportforums.cisco.com/message/2006396#2006396), while LMS 3.2 is currently only on my test box.
Here's the proc status around 5pm yesterday:
13.CWAPublisherAdministrator has shut down this server00001/04/10 16:41:5001/04/10 16:44:38
Here's the status overnight this morning:
1.1177Never started000N/ANot applicable
2.1195Never started000N/ANot applicable
3.1293Never started000N/ANot applicable
4.1390Never started000N/ANot applicable
5.1391Never started000N/ANot applicable
6.1393Never started000N/ANot applicable
7.1394Never started000N/ANot applicable
8.1395Administrator has shut down this server000N/ANot applicable
9.1398Never started000N/ANot applicable
10.1399Never started000N/ANot applicable
11.1400Never started000N/ANot applicable
12.1401Never started000N/ANot applicable
13.1402Never started000N/ANot applicable
14.1403Never started000N/ANot applicable
15.1404Never started000N/ANot applicable
16.1405Never started000N/ANot applicable
17.1406Never started000N/ANot applicable
18.1407Never started000N/ANot applicable
19.1408Never started000N/ANot applicable
20.1409Never started000N/ANot applicable
21.1410Never started000N/ANot applicable
22.1562Never started000N/ANot applicable
23.1993Never started000N/ANot applicable
24.1996Never started000N/ANot applicable
25.2034Never started000N/ANot applicable
26.ANIDbEngineProgram started - No mgt msgs received187670001/04/10 16:37:53Not applicable
27.ANIServerRunning with busy flag set193770001/04/10 16:40:49Not applicable
28.CampusOGSServerAdministrator has shut down this server00001/04/10 16:11:3001/04/10 16:32:15
29.ChangeAuditAdministrator has shut down this server0-113001/04/10 16:11:5901/04/10 16:31:56
30.CmfDbEngineProgram started - No mgt msgs received193810001/04/10 16:40:54Not applicable
31.CmfDbMonitorFailed to run00601/04/10 16:11:1401/04/10 16:40:58
32.CMFOGSServerProgram started - No mgt msgs received194600001/04/10 16:41:10Not applicable
33.ConfigMgmtServerAdministrator has shut down this server0-113001/04/10 16:11:3901/04/10 16:32:05
34.CSDiscoveryAdministrator has shut down this server000N/ANot applicable
35.CSRegistryServerRunning normally188090001/04/10 16:38:02Not applicable
36.CTMJrmServerRunning normally195720001/04/10 16:41:31Not applicable
37.CWAPublisherAdministrator has shut down this server00001/04/10 16:41:5001/04/10 16:44:38
38.DCRDevicePollAdministrator has shut down this server000N/ANot applicable
39.DCRServerRunning normally194000001/04/10 16:40:58Not applicable
40.diskWatcherRunning normally196300001/04/10 16:41:41Not applicable
41.EDSRunning normally192930001/04/10 16:40:22Not applicable
42.EDS-GCFAdministrator has shut down this server00001/04/10 16:11:3901/04/10 16:33:46
43.ESSProgram started - No mgt msgs received186730001/04/10 16:37:35Not applicable
44.EssentialsDMRunning normally194680001/04/10 16:41:15Not applicable
45.EssMonitorRunning normally186770001/04/10 16:37:39Not applicable
46.EventFrameworkProgram started - No mgt msgs received187080001/04/10 16:37:45Not applicable
47.FDRewinderAdministrator has shut down this server000N/ANot applicable
48.ICServerAdministrator has shut down this server00001/04/10 16:11:3901/04/10 16:32:07
49.IpmDbEngineProgram started - No mgt msgs received187270001/04/10 16:37:49Not applicable
50.IPMOGSServerAdministrator has shut down this server0-113001/04/10 16:12:0301/04/10 16:31:52
51.IPMProcessProgram started - No mgt msgs received195950001/04/10 16:41:37Not applicable
52.jrmRunning normally195380001/04/10 16:41:24Not applicable
53.LicenseServerProgram started - No mgt msgs received192420001/04/10 16:40:13Not applicable
54.MACUHICRunning normally187800001/04/10 16:37:57Not applicable
55.NameServerProgram started - No mgt msgs received192460001/04/10 16:40:14Not applicable
56.NameServiceMonitorRunning normally192870001/04/10 16:40:18Not applicable
57.OpsxmlDbEngineProgram started - No mgt msgs received187960001/04/10 16:37:58Not applicable
58.OpsXMLRuntimeProgram started - No mgt msgs received196410001/04/10 16:41:46Not applicable
59.PMCOGSServerAdministrator has shut down this server00001/04/10 16:11:3901/04/10 16:32:09
60.ProcSysBusProgram started - No mgt msgs received196340001/04/10 16:41:41Not applicable
61.RMEDbEngineProgram started - No mgt msgs received187130001/04/10 16:37:45Not applicable
62.RMEOGSServerProgram started - No mgt msgs received194780001/04/10 16:41:19Not applicable
63.SyslogAnalyzerAdministrator has shut down this server0-113001/04/10 16:11:5901/04/10 16:31:55
64.SyslogCollectorProgram started - No mgt msgs received187100001/04/10 16:37:45Not applicable
65.TomcatMonitorRunning normally188640001/04/10 16:38:07Not applicable
66.UTLITERunning normally187840001/04/10 16:37:58Not applicable
67.UTMajorAcquisitionTransient terminated00001/05/10 00:00:0701/05/10 00:34:51
68.UTManagerAdministrator has shut down this server02001/04/10 16:11:3901/04/10 16:32:04
69.VNMServerProgram started - No mgt msgs received187920001/04/10 16:37:58Not applicable
70.WlseUHICRunning normally187880001/04/10 16:37:58Not applicable
I also want to note that after my manual dmgtd restart, and prior to the installation of the single CiscoView Cat3560 pkg mentioned above, the only processes that didn't come back were:
CWAPublisher Administrator has shut down this server 0 0 0 01/04/10 1#:##:## 01/04/10 1#:##:##
DCRDevicePoll Administrator has shut down this server 0 0 0 N/A Not applicable
Joe Clarke Tue, 01/05/2010 - 09:01
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
You definitely have a process problem.  Has the /opt/CSCOpx/Psu.Lock disappeared?  If so, go ahead and restart dmgtd manually, and see if the processes come back up.
yjdabear Tue, 01/05/2010 - 09:11
After dmgtd stop, I still have these procs up. Should I go ahead with starting dmgtd, or is there something awry here?
casuser 23883     1   0   Dec 23 ?           0:11 /opt/vgi/csco/CSCOpx/objects/wfengine/program/PolicyScheduler
casuser 23878     1   0   Dec 23 ?           0:06 /opt/vgi/csco/CSCOpx/objects/wfengine/program/DataStore
casuser 23880     1   0   Dec 23 ?           0:13 /opt/vgi/csco/CSCOpx/objects/wfengine/program/GGLogger
casuser 23879     1   0   Dec 23 ?           0:07 /opt/vgi/csco/CSCOpx/objects/wfengine/program/GGScript
casuser 23882     1   0   Dec 23 ?           1:31 /opt/vgi/csco/CSCOpx/objects/wfengine/program/OpsBREngine
Joe Clarke Tue, 01/05/2010 - 09:13
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
No, these need to be stopped manually before dmgtd can be properly restarted.  Send them a SIGTERM, and if that doesn't work, move to a SIGKILL.
yjdabear Tue, 01/05/2010 - 09:34
Those procs were killed with SIGTERM just fine. Here's the current proc status. Everything seems to have come up fine. Overall, this seems to mirror what I've seen with LMS 3.1 Device Pkg Update regarding its inability to restart everything properly though.
6.1392Never started000N/ANot applicable
7.1393Never started000N/ANot applicable
8.1394Never started000N/ANot applicable
9.1395Never started000N/ANot applicable
10.1398Never started000N/ANot applicable
11.1399Never started000N/ANot applicable
12.1400Never started000N/ANot applicable
13.1401Never started000N/ANot applicable
14.1402Never started000N/ANot applicable
15.1403Never started000N/ANot applicable
16.1404Never started000N/ANot applicable
17.1405Never started000N/ANot applicable
18.1406Never started000N/ANot applicable
19.1407Never started000N/ANot applicable
20.1408Never started000N/ANot applicable
21.1409Never started000N/ANot applicable
22.1410Never started000N/ANot applicable
23.1562Never started000N/ANot applicable
24.1993Never started000N/ANot applicable
25.1996Never started000N/ANot applicable
26.2034Never started000N/ANot applicable
27.ANIDbEngineProgram started - No mgt msgs received190001/05/10 12:23:35Not applicable
28.ANIServerRunning with busy flag set5850001/05/10 12:26:33Not applicable
29.CampusOGSServerProgram started - No mgt msgs received6570001/05/10 12:26:57Not applicable
30.ChangeAuditProgram started - No mgt msgs received7980001/05/10 12:27:33Not applicable
31.CmfDbEngineProgram started - No mgt msgs received5860001/05/10 12:26:37Not applicable
32.CmfDbMonitorRunning normally6220001/05/10 12:26:41Not applicable
33.CMFOGSServerProgram started - No mgt msgs received6550001/05/10 12:26:53Not applicable
34.ConfigMgmtServerProgram started - No mgt msgs received7040001/05/10 12:27:06Not applicable
35.CSDiscoveryNever started000N/ANot applicable
36.CSRegistryServerRunning normally710001/05/10 12:23:43Not applicable
37.CTMJrmServerRunning normally7840001/05/10 12:27:24Not applicable
38.CWAPublisherProgram started - No mgt msgs received8560001/05/10 12:27:45Not applicable
39.DCRDevicePollNever started000N/ANot applicable
40.DCRServerRunning normally6230001/05/10 12:26:42Not applicable
41.diskWatcherRunning normally8350001/05/10 12:27:37Not applicable
42.EDSRunning normally5070001/05/10 12:26:06Not applicable
43.EDS-GCFRunning normally7060001/05/10 12:27:07Not applicable
44.ESSProgram started - No mgt msgs received299540001/05/10 12:23:17Not applicable
45.EssentialsDMRunning normally6580001/05/10 12:26:57Not applicable
46.EssMonitorRunning normally299550001/05/10 12:23:21Not applicable
47.EventFrameworkProgram started - No mgt msgs received299910001/05/10 12:23:27Not applicable
48.FDRewinderNever started000N/ANot applicable
49.ICServerRunning normally7030001/05/10 12:27:06Not applicable
50.IpmDbEngineProgram started - No mgt msgs received80001/05/10 12:23:31Not applicable
51.IPMOGSServerProgram started - No mgt msgs received8340001/05/10 12:27:37Not applicable
52.IPMProcessProgram started - No mgt msgs received8000001/05/10 12:27:33Not applicable
53.jrmRunning normally7090001/05/10 12:27:07Not applicable
54.LicenseServerProgram started - No mgt msgs received4650001/05/10 12:25:58Not applicable
55.MACUHICRunning normally540001/05/10 12:23:39Not applicable
56.NameServerProgram started - No mgt msgs received4660001/05/10 12:25:58Not applicable
57.NameServiceMonitorRunning normally5030001/05/10 12:26:02Not applicable
58.OpsxmlDbEngineProgram started - No mgt msgs received580001/05/10 12:23:39Not applicable
59.OpsXMLRuntimeProgram started - No mgt msgs received8510001/05/10 12:27:41Not applicable
60.PMCOGSServerProgram started - No mgt msgs received7020001/05/10 12:27:06Not applicable
61.ProcSysBusProgram started - No mgt msgs received8360001/05/10 12:27:37Not applicable
62.RMEDbEngineProgram started - No mgt msgs received299930001/05/10 12:23:27Not applicable
63.RMEOGSServerProgram started - No mgt msgs received6650001/05/10 12:27:01Not applicable
64.SyslogAnalyzerProgram started - No mgt msgs received7990001/05/10 12:27:33Not applicable
65.SyslogCollectorProgram started - No mgt msgs received299920001/05/10 12:23:27Not applicable
66.TomcatMonitorRunning normally1180001/05/10 12:23:47Not applicable
67.UTLITERunning normally550001/05/10 12:23:39Not applicable
68.UTMajorAcquisitionNever started000N/ANot applicable
69.UTManagerRunning normally7050001/05/10 12:27:06Not applicable
70.VNMServerProgram started - No mgt msgs received570001/05/10 12:23:39Not applicable
71.WlseUHICRunning normally560001/05/10 12:23:39Not applicable
Joe Clarke Tue, 01/05/2010 - 10:47
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
I have never seen such a problem on Solaris with LMS 3.1 or 3.2.  Device package upgrades always restore a working system.  If you can reliably reproduce, it may be helpful to open a TAC case on your next package update so one can look at the processes as they come back up.
