BNC E1 interface on a 2821?
Jan 4th, 2010
I ordered 2 E1's (4M total) from an ISP in Amman Jordan (Zain) and the only interface they supply is BNC.  How do I interface with this?   Does the NM-1T3/E3 do 4M subrate?
gkonowal1 Mon, 01/04/2010 - 13:30
Not connecting to E3, the ISP is providing 2- E1's for a total of 4M BW......the NM-1T3/E3 was the only module I found in the cataloge but I didnt know if it supported subrate (4M) traffic.
thx
paolo bevilacqua Mon, 01/04/2010 - 13:27
  • Hall of Fame,
    Founding Member
Using VWIC-2MFT-xxx or HWIC-4T1/E1, in both cases, CAB-E1-RJ45BNC.
Regarding NM-E3/T3, you cannot connect it to E1 interfaces. Subrate does not mean doing that.
paolo bevilacqua Mon, 01/04/2010 - 13:35
  • Hall of Fame,
    Founding Member
Baluns are not necessary anymore. The referenced cable is not a balun, just a phisical adapter,
The Cisco 4-Port Clear Channel T1/E1 HWIC is software-configurable between E1 or T1 operation, balanced or unbalanced E1 termination, and CSU/DSU
http://www.cisco.com/en/US/prod/collateral/modules/ps5949/product_data_sheet0900aecd80710c77.html
Same is true for all currently produced cards.
paolo bevilacqua Mon, 01/04/2010 - 13:44
  • Hall of Fame,
    Founding Member
It does support subrate. You will need 12.3(8)T IOS.
As mentioned before. T3/E3 subrate DOES NOT allow to connect a T1 or E1 circuit.
Reza Sharifi Mon, 01/04/2010 - 13:52
  • Cisco Designated VIP,
    2017 LAN
Hi Paolo,
So, does it have to connect to a T3/ET to subrate?
Reza
paolo bevilacqua Mon, 01/04/2010 - 13:54
  • Hall of Fame,
    Founding Member
He have to use one of T1/E1 cards indicated above, to connect the E1 circuits.
gkonowal1 Mon, 01/04/2010 - 13:54
so options......
I will be getting 2 seperate E1's from the ISP on cable.  They will use PPP to combine into 4M usable BW.
1) I can use the 4-Port Clear Channel T1/E1 High-Speed WAN Interface Card (RJ jack interface), I will still need to convert from BNC to ENet? correct? or
2) Use the NM-1T3/E3 with the 12.3(8)T IOS? cable interface....correct on both or is one incorrect?
paolo bevilacqua Mon, 01/04/2010 - 13:58
  • Hall of Fame,
    Founding Member
Yes, as indicated before.
Use the cable indicated before.
Cannot use NM-1T3/E3, as indicated before.
Please remember to rate useful posts clicking on the stars below.
