NX5K licenses
Jan 4th, 2010
Hello everybody
I was using the Cisco Tools Configuration to a Nexus 5010, but in the Software License Options mention 2 License, I have a question about that:
  1. N5010-SSK9. Nexus 5010 Storage Protocols Services License.
  2. N5000FMS1K9.  Nexus 5000 Fabric Manager Server License.
In the ordering information I understand that the N5010-SSK9 is to rich features of the table 4 : http://www.cisco.com/en/US/prod/collateral/switches/ps9441/ps9670/product_bulletin_c25-551648_ps9670_Products_Bulletin.html
  • But can anybody tell me what is N5010-SSK9 for? when should I use that License?
  • If I only have one NX5K, these licenses are needed?
Thanks a lot,
conmurph Mon, 01/04/2010 - 16:57
  • Cisco Employee,
Hi Rene,
As I understand, the N5010-SSK9 license is only required if you need the following features:
  • Native Fibre Channel
  • FCoE
  • NPV
  • FC Port Security
  • Fabric Binding
From the following link, any feature not included in the Storage Services                 license package is bundled with the                  Cisco NX-OS software and is provided with the switch hardware at no additional charge.
http://www.cisco.com/en/US/docs/switches/datacenter/nexus5000/sw/configuration/nxos/Cisco_Nexus_5000_Series_NX-OS_Software_Configuration_Guide_chapter5.html#con_1476017
Cheers,
Conor
Rene Melendez C... Mon, 01/04/2010 - 17:37
Thanks Cheers,
I made a mistake, I was referring to the license N5000FMS1K9 (Nexus 5000 Fabric Manager Server License), do you have idea when is required that license?
conmurph Mon, 01/04/2010 - 17:56
  • Cisco Employee,
Hi Rene,
It should be the Fabric Manager Server license and allows access to certain Cisco Fabric Manager features. It's required for features such as historical performance monitoring, Cisco Fabric Manager java client login  to a remote server, report generation and viewing with the Web Client.
I've found the following document on the Nexus 5000 Fabric Manager Server which might give you a bit more information.
https://www.cisco.com/en/US/docs/switches/datacenter/nexus5000/sw/configuration/guide/fm/fms.html#wp248159
You can run the unlicensed version of Fabric Manager.
Cheers,
Conor
Rene Melendez C... Tue, 01/05/2010 - 06:58
I can look in the link
Note
The unlicensed Cisco Fabric Manager can only monitor and configure one fabric at a time. You must use the Open menu to switch to a new fabric, which causes the application to stop monitoring the previous one and to rediscover the new fabric.
I only have a NX5K i don´t have MDS, so that I thinks that unlicensed Cisco Fabric Manager  is sufficient.
Thanks again,
