Spanning Tree
Jan 4th, 2010
I have two 4000 switches currently are configured as a root bridge for 10 vlans.  VLAN 100,200,6,106 etc.  I will be connecting a 6509 switch with 2 Port Channels (4 physical ports) to (2) 4000 switches as Layer II trunks, and will also configure the above VLANs in 6509.  6509 will act as an internim switch for couple of months since we are in process of redesigning our data center.  How do I  make sure that 6509 doesn't become a root bridge for the above VLANs to avoid spanning tree loop.  As far as I am concerned, the 6509 will not become a root bridge if the priority for the above VLANs are lower on 4000 switches.
What do I need to configure on Port channel ports to make (1) port channel connecting to 4000 (A) switch as a forwarding path, and the other Port Channel connecting to 4000(B) switch as a backup path.
Marwan ALshawi Mon, 01/04/2010 - 23:59
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Best Publication, December 2015
lets say you have vlan 100 and 200
switch A is the root for these vlans ( lower priority)
switch B is the secondary next lower priority
you can do
switch A
spanning-tree vlan 10,200 root primary
switch B
spanning-tree vlan 10,200 root secondary
in the switch 6500 make the priority of the above vlans to the highest in this case you will make sure that this switch will not become a root as long as Switch A or switch B is up
also int the L2 channels add the fllowing command in Switch A and Switch B going to the 6500 switch
spanning-tree guard root
this will disable the interface of switch A and B to the 6500 in case of switch 6500 is elected as root for any vlan
once you have Switch A the root for the required vlans and switch B  the secondary root
the path will be through switch A and through switch B will be in blocking ( back up ) from the 6500 switch prespective,   this is default and you do not need any change to STP costs
good luck
if helpful Rate
KARUPPUCHAMY MA... Tue, 01/05/2010 - 00:05
  • Silver, 250 points or more
As far as I am concerned, the 6509 will not become a root bridge if the priority for the above VLANs are lower on 4000 switches.  --No. It is not correct.
The lowest priority wil become the root bridge.In your scenario, we have to increase the priority value of 6509 switch and ot should be greater that 4500 switch.so that 6509 switch will not become a root bridge.
Have you inter-connected these 4500(A) and 4500(B).Need more info.
Because, if you have connected these 4500(A) and 4500(B), then make 4500(A) as a root bridge for all the 10 vlans then, the port-channel from 6500 to 4500(A) will be primary path and 4500(B) will be secondary path.
Karuppuchamy CCIE(R&S),CCSP
abbas.ali Tue, 01/05/2010 - 00:26
Thanks guys!  Yes the two 4000 switches are connected together as a Layer II.
KARUPPUCHAMY MA... Tue, 01/05/2010 - 00:31
Hope u got the solution..
for more info please have a look on the beloe URLs
http://www.cisco.com/en/US/docs/switches/lan/catalyst4000/7.5/configuration/guide/spantree.html  --- For Cisco 4500 Switch
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/catos/5.x/configuration/guide/spantree.html --- For Cisco 6500 Switch.
