01-04-2010 11:48 PM - edited 03-15-2019 08:56 PM
After we create the customize image for the IP phone, how can we make IP Phone to boot up with new customeize image whenever user logs in to his IP Phone, instead of the default image(List.xml)
Regds,
Navin
01-05-2010 07:12 AM
You cannot
This has been discussed plenty of times before, PLEASE SEARCH NetPro for answers before posting
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
01-05-2010 02:05 PM
This has been discussed in many fourms before: you cannot boot with the image. It will default to the list.xml, then you can select the new corporate background.
