telnet from topology services
Answered Question
Jan 4th, 2010
hello
we are upgrading from CW LMS 2.6 to 3.2
we found that in this version we are not able to telnet to devices from topology services
in this link
http://www.cisco.com/en/US/docs/net_mgmt/ciscoworks_common_services_software/3.3/release/notes/cs33rel.html#wp54971
i found this bug : CSCsh49922
i think this is our case.
they give only the solution for Windows XP client systems with Internet Explorer 7 browser. the solution works but
is there any other solution if i am using Windows server 2003 with IE 8  (i am telnetting from the server itself).
actually i permit telnet to devices only from ciscoworks machine (acl).
i tried firefox with windows server 2003 but it was not successfull
Correct Answer by Joe Clarke about 7 years 1 month ago
You should uninstall all versions of the JPI, then try and launch Topology Services from the server.  You will then get a page which has a link to download JPI 1.6.0_11 from the server itself.  Download, and install this plug-in as the local Administrator.  Then, relaunch your browser, and relaunch Topology Services.  You should see some additional jar files installed.  At this point, you can switch from local Administrator to your actual user, and Campus should work.  Telnet should aslo work provided you have the telnet.exe binary installed on the system.
Overall Rating: 4 (2 ratings)
Joe Clarke Mon, 01/04/2010 - 23:54
IE 8.0 is not supported at the moment.  That said, I was under the impression that the same IE 7.0 solution would work for IE 8.0.  Firefox 3.0 has been tested, and does work.  I have used it the lab, and telnet is working just fine (using JPI 1.6.0_11 on the 2003 client).
ohassairi Tue, 01/05/2010 - 00:32
thank you joe for your reply.
i am trying to download the JPI that you suggested but i can't find it.
can you suggest one good url?
thanks
Correct Answer
Joe Clarke Tue, 01/05/2010 - 08:58
ohassairi Thu, 01/07/2010 - 02:03
thank you joe.
i can telnet using the 1.6.0_11 JPI with firefox
ahmed zaki kamel Sun, 07/10/2011 - 06:45
i removed any explorer versions and used only IE 6 installed on windows server 2003
i copied the file telnet.exe from windows\system32 to desktop  then tried to open the telnet from the topology
it works fine
