NSS3000 - Disk support
I want to buy a NSS3000, but have a question. In the specs I see that it supports 4 disks with a maximum of 4TB, but you should use disks from the supported disk list. In this list I see that it supports WD disks of 2TB. So my question is : can I install 4 disks of 2TB (to get 8TB), or is there a technical reason this doesn't work ?
greetz
Geert
