Access with telnet to router over isdn line
Answered Question
Jan 5th, 2010
Hi all,
Is it possible to configure access with telnet to a router over a isdn line.. for management...???
it is an Callmanager express, so normal the isdn line is in use for voice...
Correct Answer by paolo bevilacqua about 7 years 3 months ago
As indicated before: "the voice BRI cards of cisco router do not support data"
In other words: Data BRI cards are different ones, and do not support voice.
Moreover: the rotuer that you have do not have an ISDN modem inside. these are sold seprately in modules of 6.
Overall Rating: 5 (1 ratings)
paolo bevilacqua Tue, 01/05/2010 - 03:53
  • Hall of Fame,
    Founding Member
No, because the voice BRI interface do not support data connections.
kennis1977 Tue, 01/05/2010 - 05:38
Isdn does support data...however... is it also possible to support data and voice..?
so when a modem calls over the isdn line it gives access to the router with telnet.
because there is a command isdn incoming voice data and isdn incoming voice modem
Correct Answer
paolo bevilacqua Tue, 01/05/2010 - 05:46
  • Hall of Fame,
    Founding Member
