Multiple BSSIDs not working on 1121G AP
Answered Question
Jan 5th, 2010
I am trying to setup some 1121G autonomous access points to broadcast a couple of SSIDs - Each SSID is in its own VLAN and this is all working fine when I am not using multiple BSSID.
I have got to the stage where I can see all 3 SSIDs being broadcast but I cannot connect to any of them.  One SSID is totally open, one is using EAP and the other is WPA/PSK.
Any ideas of why this may be happening as I am totally clueless now..  revert back to broadcasting a single SSID and all three SSIDs work again.
I can post the config if that would help.
Correct Answer by Stephen Rodriguez about 7 years 4 months ago
Network ID has to do with using a WLSM, and tunneling the traffic back to the 6500.  If it's working without the Network ID, that's great.
Overall Rating: 5 (1 ratings)
Stephen Rodriguez Tue, 01/05/2010 - 08:18
  • Purple, 4500 points or more
What you are describing happens a lot with the IOS AP, when you have implemented the mbssid commands, i.e. Under the Dot11Radio0 mbssid, and under the SSID mbssid guest-mode.  This has to do with driver interactions with the client.  You may want to check if updated drivers from the chipset manufacturer resolve the issue.
t005114902 Tue, 01/05/2010 - 08:55
Hi Steve
I kept on trying different things with the configuration and have finally got it working by not putting anything in the "Network ID" field in the GUI.  I have no idea why this has kick started it into behaving because it clearly states in the cisco docs that when setting up multiple bssid's you must put a value in this field for each SSID.
Tried this on a few APs and it is working exactly as I need it now.  Got all 3 SSIDs being broadcast and can connect to each of them in the correct vlan.
Correct Answer
Stephen Rodriguez Tue, 01/05/2010 - 08:59
t005114902 Tue, 01/05/2010 - 09:06
Ok thanks for the info, it didn't mention anything about WLSM or the 6500 switch in the docs but have accepted your answer so hopefully this
might help someone else in the future.
Thanks again.
