ACE : Rserver connection failures ?
Jan 5th, 2010
In a productive environment, I observe rserver counters and I can read several connection failures. However, the site seems to work correctly.
What are the conditions under which he ACE increments the connection failures counter ?
Here is an extract of the show serverfarm command :
CH01AC03/P-115-A# sh serverfarm NCL_FARM_PROD
serverfarm     : NCL_FARM_PROD, type: HOST
total rservers : 6
                                                ----------connections-----------
       real                  weight state        current    total      failures
   rserver: HQBUUN203
       10.56.7.209:443       12     OPERATIONAL  11         2363414    334
   rserver: HQBUUN205
       10.56.7.210:443       12     OPERATIONAL  11         2321347    2055
   rserver: HQBUUN221
       10.56.7.94:443        8      OPERATIONAL  10         1611561    1270
   rserver: HQBUUN222
       10.56.7.93:443        8      OPERATIONAL  20         1608550    189
   rserver: HQVEUN218
       10.56.7.96:443        8      OPERATIONAL  15         1532865    1307
   rserver: HQVEUN219
       10.56.7.95:443        8      OPERATIONAL  12         1607162    304
Thank you for any hints
Yves Haemmerli
Gilles Dufour Tue, 01/05/2010 - 08:58
  • Cisco Employee,
Yves,
normally only RST from the rserver or no response to SYN from the rserver are counted as failure.
However, we had issues with this as identified in  CSCtd22008 "ACE- Client RST in End-to-End SSL generates Rserver conn-failures."
An old one is CSCsh14278 "sh serverfarm failure conn incremented for successful connection".
So, if you want to be sure, the only option is to capture a sniffer trace.
Gilles.
