Distribute access points by the controllers with WCS
Jan 5th, 2010
I can control the way that the APs are destributed by the different controllers? Or this process it's automatic?
I want to upgrade 4 WLCs that are controlled by a WCS. What I want to do it's to transfer the Access Points registered with two of the controllers to the other two controllers and upgrade the first two. Then transfer the access points to the other two controllers and upgrade the other two. It's this possible? What's the best way of do it?
Thank you.
Best regards,
Overall Rating: 4 (2 ratings)
Stephen Rodriguez Tue, 01/05/2010 - 08:54
This is entirely possible.  If you use the WCS, you can push templates that will change the Primary Controller on the AP, just push the AP to the WLC that has availability.  Once the WLC are updated, you can change the Primary back.
Lucien Avramov Thu, 01/07/2010 - 14:44
Leaving the templates alone, you can select primary, secondary and tertiary controller order you want the AP to follow from the AP configuration menu in WCS
Norberto Salgado Fri, 01/08/2010 - 08:17
thank you for your reply. I already have done the upgrade and worked well
Best regards!
Trending Topics - Security & Network
