E1 R2-digital configuration in Riyadh on H.323 Gateway
Jan 5th, 2010
Hi All,
Does anybody know where I can get a sample configuration for a voice gateway with E1 r2-digital connections to STC in Riyadh. I can receive calls from the PSTN but outgoing calls fail.
I have the following configuration on my Router.
version 12.4
service timestamps debug datetime
service timestamps log datetime
service password-encryption
hostname vsaruhvgw02
boot-start-marker
boot-end-marker
card type e1 0 0
logging buffered 51200
enable secret 5 <removed>
no aaa new-model
clock timezone MST 3
network-clock-participate wic 0
dot11 syslog
ip cef
ip domain name voice.ds.corp
ip name-server 10.10.140.30
ip name-server 10.11.140.30
voice-card 0
dspfarm
voice service voip
h323
crypto pki trustpoint TP-self-signed-307895532
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-307895532
revocation-check none
rsakeypair TP-self-signed-307895532
crypto pki certificate chain TP-self-signed-307895532
certificate self-signed 01
  3082024F 308201B8 A0030201 02020101 300D0609 2A864886 F70D0101 04050030
  30312E30 2C060355 04031325 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 33303738 39353533 32301E17 0D303931 32323931 31313935
  FB9FEC73 75316441 33C46993 B6656DA0 CA67FA
      quit
username admin privilege 15 secret 5 <removed>
archive
log config
  hidekeys
controller E1 0/0/0
framing NO-CRC4
ds0-group 0 timeslots 1-10 type r2-digital r2-compelled ani
ds0-group 1 timeslots 11-15,17-30 type r2-digital r2-compelled ani
cas-custom 0
  country saudiarabia
  ani-digits min 4 max 20
cas-custom 1
  country saudiarabia use-defaults
controller E1 0/0/1
interface GigabitEthernet0/0
description LAN Connection
ip address 10.10.140.11 255.255.255.0
duplex auto
speed auto
h323-gateway voip bind srcaddr 10.10.140.11
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 10.10.140.254
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
access-list 23 permit 10.10.10.0 0.0.0.7
control-plane
voice-port 0/0/0:0
cptone SA
voice-port 0/0/0:1
cptone SA
no mgcp timer receive-rtcp
dial-peer voice 1 pots
destination-pattern .T
direct-inward-dial
port 0/0/0:1
dial-peer voice 1000 voip
preference 1
destination-pattern 68..
session target ipv4:10.10.140.1
dtmf-relay h245-alphanumeric
codec g711ulaw
gateway
timer receive-rtp 1200
line con 0
exec-timeout 120 0
login local
line aux 0
line vty 0 4
exec-timeout 0 0
privilege level 15
login local
transport input telnet ssh
line vty 5 15
access-class 23 in
privilege level 15
login local
scheduler allocate 20000 1000
ntp clock-period 17180112
ntp server 10.10.140.1
ntp server 10.10.140.2
end
Overall Rating: 0 (1 ratings)
paolo bevilacqua Tue, 01/05/2010 - 04:59
  • Hall of Fame,
    Founding Member
Take "debug vpm signal" with "term mon".
Max Schmid Tue, 01/05/2010 - 05:03
Here is the debug output.
*Jan  5 13:02:31: htsp_timer_stop3 htsp_setup_req
*Jan  5 13:02:32: htsp_process_event: [0/0/0:1(13), R2_Q421_IDLE, E_HTSP_SETUP_REQ]
*Jan  5 13:02:32: r2_q421_seize(0/0/0:1(13)) E_HTSP_SETUP_REQ DNIS=4791234 ANI=6969
*Jan  5 13:02:32: r2_q421_seize(0/0/0:1(13)) Tx SEIZUREvnm_dsp_set_sig_state:[R2 Q.421 0/0/0:1(13)] set signal state = 0x0
*Jan  5 13:02:32: htsp_timer - 5000 msec
*Jan  5 13:02:32: htsp_process_event: [0/0/0:1(13), R2_Q421_OG_SEIZE, E_DSP_SIG_1100]
*Jan  5 13:02:32: r2_q421_seize_ack(0/0/0:1(13)) Rx SEIZE ACK
*Jan  5 13:02:32: htsp_timer_stop
*Jan  5 13:02:32: r2_reg_start_dialing(0/0/0:1(13))
*Jan  5 13:02:32: r2_reg_process_event: [0/0/0:1(13), R2_REG_IDLE, E_R2_REG_START_DIAL(91)]
*Jan  5 13:02:32: r2_reg_start_dial_delay(0/0/0:1(13)) dialout delay 200
*Jan  5 13:02:32: r2_reg_timer(0/0/0:1(13)) 200 msec
*Jan  5 13:02:32: r2_reg_process_event: [0/0/0:1(13), R2_REG_IDLE, E_R2_REG_EVENT_TIMER(84)]
*Jan  5 13:02:32: r2_reg_start_dial(0/0/0:1(13))
*Jan  5 13:02:32: R2 Outgoing Voice(0/0): DSX (E1 0/0/0:12): STATE: R2_OUT_IDLE R2 Got Event R2_START
*Jan  5 13:02:32: r2_reg_generate_digits(0/0/0:1(13)): Tx digit '#'
*Jan  5 13:02:32: r2_reg_generate_digits(0/0/0:1(13)): Tx digit '4'
*Jan  5 13:02:32: htsp_digit_ready_up(0/0/0:1(13)): Rx digit='5'
*Jan  5 13:02:32: R2 Outgoing Voice(0/0): DSX (E1 0/0/0:12): STATE: R2_OUT_PROCESS_A R2 Got Event 5
*Jan  5 13:02:32: htsp_digit_ready(0/0/0:1(13)): Rx digit='#'
*Jan  5 13:02:32: R2 Outgoing Voice(0/0): DSX (E1 0/0/0:12): STATE: R2_OUT_PROCESS_A R2 Got Event R2_TONE_OFF
*Jan  5 13:02:32: r2_reg_generate_digits(0/0/0:1(13)): Tx digit '1'
*Jan  5 13:02:32: r2_reg_generate_digits(0/0/0:1(13)): Tx digit '6'
*Jan  5 13:02:32: r2_reg_generate_digits(0/0/0:1(13)): Tx digit '9'
*Jan  5 13:02:33: htsp_digit_ready_up(0/0/0:1(13)): Rx digit='5'
*Jan  5 13:02:33: R2 Outgoing Voice(0/0): DSX (E1 0/0/0:12): STATE: R2_OUT_PROCESS_A R2 Got Event 5
*Jan  5 13:02:33: r2_reg_generate_digits(0/0/0:1(13)): Tx digit '#'
*Jan  5 13:02:33: htsp_digit_ready(0/0/0:1(13)): Rx digit='#'
*Jan  5 13:02:33: R2 Outgoing Voice(0/0): DSX (E1 0/0/0:12): STATE: R2_OUT_PROCESS_A R2 Got Event R2_TONE_OFF
*Jan  5 13:02:33: r2_reg_generate_digits(0/0/0:1(13)): Tx digit '6'
*Jan  5 13:02:33: r2_reg_generate_digits(0/0/0:1(13)): Tx digit '9'
*Jan  5 13:02:33: r2_reg_generate_digits(0/0/0:1(13)): Tx digit '*'
*Jan  5 13:02:33: htsp_digit_ready_up(0/0/0:1(13)): Rx digit='1'
*Jan  5 13:02:33: R2 Outgoing Voice(0/0): DSX (E1 0/0/0:12): STATE: R2_OUT_PROCESS_A R2 Got Event 1
*Jan  5 13:02:33: r2_reg_generate_digits(0/0/0:1(13)): Tx digit '7'
*Jan  5 13:02:34: htsp_digit_ready(0/0/0:1(13)): Rx digit='#'
*Jan  5 13:02:34: R2 Outgoing Voice(0/0): DSX (E1 0/0/0:12): STATE: R2_OUT_PROCESS_A R2 Got Event R2_TONE_OFF
*Jan  5 13:02:34: r2_reg_generate_digits(0/0/0:1(13)): Tx digit '9'
*Jan  5 13:02:34: htsp_digit_ready_up(0/0/0:1(13)): Rx digit='1'
*Jan  5 13:02:34: R2 Outgoing Voice(0/0): DSX (E1 0/0/0:12): STATE: R2_OUT_PROCESS_A R2 Got Event 1
*Jan  5 13:02:34: r2_reg_generate_digits(0/0/0:1(13)): Tx digit '#'
*Jan  5 13:02:34: r2_reg_generate_digits(0/0/0:1(13)): Tx digit '1'
*Jan  5 13:02:34: r2_reg_generate_digits(0/0/0:1(13)): Tx digit '2'
*Jan  5 13:02:34: r2_reg_generate_digits(0/0/0:1(13)): Tx digit '3'
*Jan  5 13:02:34: r2_reg_generate_digits(0/0/0:1(13)): Tx digit '4'
*Jan  5 13:02:36: htsp_digit_ready_up(0/0/0:1(13)): Rx digit='3'
*Jan  5 13:02:36: R2 Outgoing Voice(0/0): DSX (E1 0/0/0:12): STATE: R2_OUT_PROCESS_A R2 Got Event 3
*Jan  5 13:02:36: r2_reg_generate_digits(0/0/0:1(13)): Tx digit '#'
*Jan  5 13:02:37: htsp_digit_ready(0/0/0:1(13)): Rx digit='#'
*Jan  5 13:02:37: R2 Outgoing Voice(0/0): DSX (E1 0/0/0:12): STATE: R2_OUT_PROCESS_B R2 Got Event R2_TONE_OFF
*Jan  5 13:02:37: r2_reg_generate_digits(0/0/0:1(13)): Tx digit '1'
*Jan  5 13:02:37: htsp_digit_ready_up(0/0/0:1(13)): Rx digit='6'
*Jan  5 13:02:37: R2 Outgoing Voice(0/0): DSX (E1 0/0/0:12): STATE: R2_OUT_PROCESS_B R2 Got Event 6
*Jan  5 13:02:37: r2_reg_generate_digits(0/0/0:1(13)): Tx digit '#'
*Jan  5 13:02:37: R2 Outgoing Voice(0/0): DSX (E1 0/0/0:12): STATE: R2_OUT_WAIT_IDLE R2 Got Event R2_TONE_OFF
*Jan  5 13:02:37: r2_reg_event_proc(0/0/0:1(13)) ADDR_INFO_COLLECTED (DNIS=4791234, ANI=6969)
*Jan  5 13:02:37: r2_reg_end_dial(0/0/0:1(13))
*Jan  5 13:02:37: r2_reg_process_event: [0/0/0:1(13), R2_REG_DIALING, E_R2_REG_ADDR_COLLECTED(87)]
*Jan  5 13:02:37: r2_reg_addr_collected(0/0/0:1(13))
*Jan  5 13:02:37: R2 Outgoing Voice(0/0): DSX (E1 0/0/0:12): STATE: R2_OUT_IDLE R2 Got Event R2_STOP
*Jan  5 13:02:37: r2_reg_timer(0/0/0:1(13)) 300 msec
*Jan  5 13:02:37: htsp_dialing_done(0/0/0:1(13))
*Jan  5 13:02:37: htsp_process_event: [0/0/0:1(13), R2_Q421_OG_SEIZE_ACK, E_DSP_DIALING_DONE]
*Jan  5 13:02:37: r2_q421_dial_done(0/0/0:1(13)) E_HTSP_RELEASE_REQ
*Jan  5 13:02:37: r2_reg_dial_done(0/0/0:1(13))
*Jan  5 13:02:37: r2_reg_process_event: [0/0/0:1(13), R2_REG_DIALING, E_R2_REG_EVENT_TIMER(84)]
*Jan  5 13:02:37: r2_reg_addr_collect_to(0/0/0:1(13))htsp_alert
*Jan  5 13:02:37: htsp_call_bridged invoked
*Jan  5 13:02:37: r2_reg_event_proc(0/0/0:1(13)) ALERTING RECEIVED
*Jan  5 13:02:37: R2 Outgoing Voice(0/0): DSX (E1 0/0/0:12): STATE: R2_OUT_IDLE R2 Got Event R2_ALERTING
*Jan  5 13:02:37: htsp_timer_stop3
*Jan  5 13:02:37: htsp_process_event: [0/0/0:1(13), R2_Q421_OG_SEIZE_ACK, E_HTSP_RELEASE_REQ]
*Jan  5 13:02:37: r2_q421_clr_fwd(0/0/0:1(13)) E_HTSP_RELEASE_REQ
*Jan  5 13:02:37: r2_reg_channel_disconnected(0/0/0:1(13))
*Jan  5 13:02:37: r2_q421_clr_fwd(0/0/0:1(13)) Tx CLEAR FWDvnm_dsp_set_sig_state:[R2 Q.421 0/0/0:1(13)] set signal state = 0x8
*Jan  5 13:02:37: htsp_timer - 1000 msec
*Jan  5 13:02:37: r2_reg_process_event: [0/0/0:1(13), R2_REG_WAIT_FOR_CONNECT, E_R2_REG_DISCONNECT(89)]
*Jan  5 13:02:37: r2_reg_disconnect_idle(0/0/0:1(13))
*Jan  5 13:02:37: r2_reg_timer_stop(0/0/0:1(13))
*Jan  5 13:02:37: htsp_process_event: [0/0/0:1(13), R2_Q421_OG_CLR_FWD, E_DSP_SIG_1000]
*Jan  5 13:02:37: r2_q421_clr_fwd_idle(0/0/0:1(13)) Rx IDLE
*Jan  5 13:02:37: r2_q421_clr_fwd_idle(0/0/0:1(13)) Tx IDLEvnm_dsp_set_sig_state:[R2 Q.421 0/0/0:1(13)] set signal state = 0x8
*Jan  5 13:02:37: r2_reg_process_event: [0/0/0:1(13), R2_REG_IDLE, E_R2_REG_DISCONNECT(89)]
*Jan  5 13:02:37: r2_reg_timer_stop(0/0/0:1(13))debug vpm signal
paolo bevilacqua Tue, 01/05/2010 - 05:40
  • Hall of Fame,
    Founding Member
You are calling 4791234 from 6969, are these valid numbers ?
Max Schmid Tue, 01/05/2010 - 05:43
Yes, 4791234 is a local number in Riyadh and 6969 is my extention. The
technician from STC told me that we have to send only the extention as a
calling number.
paolo bevilacqua Tue, 01/05/2010 - 05:50
  • Hall of Fame,
    Founding Member
You are receiving a disconnect after alerting. At this point telco should monitor the call and tell you why they fail it.
Max Schmid Tue, 01/05/2010 - 06:04
I will ask them again. The last information I received from the STC
technician was that my Router was diconnectiong the call?
paolo bevilacqua Tue, 01/05/2010 - 07:21
  • Hall of Fame,
    Founding Member
It may be the htsp 5 secs timer expiring - no valid reason for that.
Which exact IOS is this ?
Max Schmid Tue, 01/05/2010 - 07:23
Cisco IOS Software, 2800 Software (C2800NM-SPSERVICESK9-M), Version
12.4(15)T10, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Mon 14-Sep-09 14:01 by prod_rel_team
ROM: System Bootstrap, Version 12.4(13r)T11, RELEASE SOFTWARE (fc1)
vsaruhvgw02 uptime is 6 days, 6 hours, 32 minutes
System restarted at 11:49:45 MST Wed Dec 30 2009
System image file is "flash:c2800nm-spservicesk9-mz.124-15.T10.bin"
paolo bevilacqua Tue, 01/05/2010 - 08:22
  • Hall of Fame,
    Founding Member
Maybe a long shot, but can you try a different image ?
Max Schmid Tue, 01/05/2010 - 10:29
Unfortunately not
I tried c2800nm-spservicesk9-mz.124-24.T2.bin but no change.
paolo bevilacqua Tue, 01/05/2010 - 11:45
  • Hall of Fame,
    Founding Member
Can you get PRI instead ?
Max Schmid Wed, 02/03/2010 - 02:42
Thanks to p.bevilacqua for the assistance.
The problem is solved! STC Does not offer PRI ISDN so I had the make R2 work.
On the gateway configuration the Tunneling Protocol was set to QSIG instead of none. When passing calls to the H.323 Gateway, the Calling Number has to be masked to the extention number and the 0 (PSTN Caccess code) prefix has to be removed. The rest uses a standard H.323 Gateway configuration. Below is the relevant working router configuration (If someone else should ever need this).
!!Cisco IOS Software, 2800 Software (C2800NM-SPSERVICESK9-M), Version 12.4(24)T2, RELEASE SOFTWARE (fc2) !
card type e1 0 0
voice call send-alert
voice service voip
qsig decode
fax protocol pass-through g711alaw
h323
  h225 timeout tcp call-idle value 2
  h225 timeout t302 1
  h225 timeout t304 1
  h225 timeout setup 1
  call start slow
controller E1 0/0/0
framing NO-CRC4
ds0-group 1 timeslots 11-15,17-31 type r2-digital r2-compelled ani
  cas-custom 0
  country saudiarabia
cas-custom 1
  disconnect-tone
ip address 10.10.140.10 255.255.255.0
duplex auto
speed auto
h323-gateway voip bind srcaddr 10.10.140.10 !
voice-port 0/0/0:0
cptone SA
voice-port 0/0/0:1
cptone SA
timeouts interdigit 2
timeouts call-disconnect 3
timeouts wait-release 2
codec g711ulaw
preference 1
direct-inward-dial
port 0/0/0:1
emadalsindi Sun, 01/16/2011 - 22:52
I was wondering if you have faced a problem with call forwarding.
Im facing weird problem. the calls are perfectly working but when a user wants to diver/fowards his calls to his mobile, the calls will fail.
can you please check where i have gone wrong, thanks.
I have different config's from you, im thinking of changing  the E1R2 to your config.
card type e1 0 0
logging message-counter syslog
no aaa new-model
clock timezone KSA 3
--More--                           dot11 syslog
ip source-route
ip cef
ip dhcp excluded-address 172.17.3.1 172.17.3.2
ip dhcp pool IPPHONES
   network 172.17.3.0 255.255.255.0
   default-router 172.17.3.1
   option 150 ip 172.17.4.2
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
--More--                           !
voice translation-rule 10
rule 1 /^.*\(....\)/ /\1/
voice translation-profile CorpSTC
translate calling 10
voice-card 0
controller E1 0/0/0
framing NO-CRC4
ds0-group 1 timeslots 1-6 type r2-digital r2-semi-compelled ani
ds0-group 2 timeslots 17-23 type r2-digital r2-semi-compelled ani
cas-custom 1
cas-custom 2
ip ssh version 2
voice-port 0/0/0:1
translation-profile outgoing CorpSTC
voice-port 0/0/0:2
voice-port 0/1/0
supervisory disconnect dualtone mid-call
no battery-reversal
cptone SA
timeouts call-disconnect 2
connection plar opx 5678
caller-id enable
voice-port 0/1/1
no battery-reversal
cptone SA
caller-id enable
ccm-manager fax protocol cisco
mgcp fax t38 ecm
dial-peer cor custom
name private
name none
dial-peer cor list calls-allowed-all
member private
dial-peer cor list calls-internal-only
member none
corlist outgoing calls-allowed-all
destination-pattern 9.T
port 0/0/0:2
dial-peer voice 6000 voip
destination-pattern 6000
session protocol sipv2
session target ipv4:172.17.4.5
           dtmf-relay sip-notify
codec g711ulaw
no vad
dial-peer voice 2 pots
incoming called-number 56..
direct-inward-dial
port 0/0/0:1
dial-peer voice 7000 voip
description AutoAttendant Prompt
destination-pattern 5678
b2bua
codec g711ulaw
no vad
         telephony-service
no auto-reg-ephone
em logout 0:0 0:0 0:0
max-ephones 40
max-dn 40
ip source-address 172.17.4.2 port 2000
auto assign 1 to 22
timeouts interdigit 3
url services http://172.17.4.5/voiceview/common/login.do
url authentication http://172.17.4.5/voiceview/authentication/authenticate.do
load 7906 SCCP11.8-3-3S
load 7910 P00403020214
load 7911 SCCP11.8-3-3S
load 7960-7940 P00308000500
load 7941 SCCP41.8-3-3S
load 7945 SCCP45.8-3-3S
load 7961 SCCP41.8-3-3S
load 7965 SCCP45.8-3-3S
time-zone 31
date-format dd-mm-yy
dialplan-pattern 1 21556.. extension-length 4 extension-pattern 56..
voicemail 6000
          max-conferences 8 gain -6
moh music-on-hold.au
dn-webedit
time-webedit
transfer-system full-consult
transfer-pattern .T
create cnf-files version-stamp 7960 Jan 12 2011 17:49:23
Max Schmid Sun, 01/16/2011 - 23:26
I have the same problem but have had no time to fix it (Has a low priority). I suspect that the forwarding fails due to the fact that STC does not allow CLIP NO SCREENING functions and when forwarding the call, the caller ID is not within the valid number range allowed to place calls on the line. I can emagine setting up a dedicated call farward CSS whrere the calling number is replaced by a valid extension number instead.
emadalsindi Mon, 01/17/2011 - 00:08
Thanks for the reply.
I thought I had a unique case.
Im still confused on how to do what you have suggested, I realize through debugging exactly what you have explained, but unfortunately, Im not quite sure how to do a by-pass solution.
Emad
emadalsindi Mon, 01/17/2011 - 01:19
I built on your comment and got it working to show as "main" number.. tricky, but works.
Thanks for your guidance.
Emad
