OS administrator login failure after upgrade from 4.2 to 6.1
Answered Question
Jan 5th, 2010
i upgraded my CCM cluster (Pub & Sub) from 4.2 to 6.1 through DMA.
All is working fine, and my new cluster is operative.
the only problem i meet is that i'm not able to login as "OS administrator" into the subscriber. But i can login properly into the pubblisher.
No problem with CM administrator's username/password for both publisher and subscriber.
There is a way in order to reset username/password for OS administrator??
thanks for any help you can provide me
Correct Answer by Jaime Valencia about 7 years 3 months ago
Correct Answer by Rob Huffman about 7 years 3 months ago
Hi there,
Have you tried the username "administrator" without the "OS"
Also check out this great thread from Michael @ Cisco;
https://supportforums.cisco.com/message/1122362#1122362
Cheers!
Rob
Overall Rating: 5 (2 ratings)
Correct Answer
Rob Huffman Tue, 01/05/2010 - 07:14
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi there,
Cheers!
Rob
