What is the corrrect syntax to create an alternatehostname in Unity Connection 7.X
jcompiano
I need to create a new certificate for tomcat to remove the SSL warnings
when users loginto Cisco PCA. When I enter set web-security alternatehostname voicemail.acme.
com
I get an error message that 4 parameters are needed and only two are found. Do I need to add existing mandatory info and if so what is the correct syntax.
thanks,
set web-security "organization unit" "orgnization name" "city name" "state name" "united states" "whatever name you want in the certificate"
Michael
6 Replies 6
htluo
Level 9
Level 9
Must have commas or spaces worng, I am getting errors when setting this up.
admin:set web-security IT,My Company,40 Acme Street Cambridge, MA, US, voicemail.acme.com
Expected 4 mandatory and up to 2 non-mandatory parmeter(s)
but 8 parameter(s) were found
Executed command unsuccessfully
Error executing command
Parameters are separated by space.  Thus if you have space in a parameter, you should quote it with quotation marks.
Hope this helps.
Michael
I got an error indicating I used unqualified characters and quotes were not in the example. Do you have any examples?
thanks
Michael
I got it working with underscores.
set web-security IT, My_Company, 40 Main_Street_Boston, MA, US, myvoicemail.com
thanks
