01-05-2010 08:35 AM - edited 03-15-2019 08:57 PM
i have a new cluster, one publisher and one subscriber, which services do you recommend to activate in each server?
thanks
01-05-2010 12:43 PM
The following links will provide you with the function of each service in CallManager
CCM 4.x
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/4_1_3/ccmsys/a02svcs.html
CUCM 5.x, 6.x, 7.x
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/service/6_1_1/admin/sasrvdes.html
It is recommended that you activate only the required components for each server in the cluster since each component that you activate adds to the server load. Each service performs specific functions for the IP telephony network and some of them run only on a single server and some needs to be run clusterwide so I believe you will need to be a little more specific on which services you are not sure and we might be able to provide you with a better answer.
01-07-2010 06:54 AM
hi, i would like to know which services do i have to enable in the publisher and the subscriber to
have a cluster, for example, tftp services in both or in the subscriber, the best practices for a simple cluster
01-07-2010 11:42 AM
It really depends on what is your cluster deployment model (i.e. how many servers), do you require dedicated TFTP, MOH, Media servers, which features do you require, i.e. AC, Web dialer, encryption....
At mimimum you need one TFTP, CM service on your subs, and depending on your redundancy model a Pub, AC if you are using AC, Extension Mobility if you are using it, IP Streaming App for media resources on chosen servers.
HTH,
Chris
01-15-2010 06:52 AM
Hi Giovanni,
I thought that you might find this useful (Table 16);
Cluster Service Activation Node Recommendations
The "Configuring Services" chapter in the Cisco Unified Serviceability Administration Guide does not include the following information that describes service activation recommendations for specific nodes in a cluster. Table 16 provides a general summary of the cluster activation recommendations for a feature service in these nodes: publisher, subscriber, TFTP, and MOH. For specific recommendations that are associated with activating a particular feature service, refer to the Cluster Service Activation Recommendations section in the "Configuring Services" chapter.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/rel_notes/7_1_3/cucm-rel_notes-713.html#wp1791070
Cheers!
Rob
