HWIC-1FE & HWIC-2FE support on C2821 router
Jan 5th, 2010
I need additional Fast Ethernet ports on a Cisco 2821 router.
I read that the C2821 supports the following:
- up to two HWIC-1FE
- 1 HWIC-2FE
Can I use 2 HWIC-1FE and 1 HWIC-2FE on the same C2821?
I was wondering whether the limitation means either 2 HWIC-1FE or 1 HWIC-2FE.
I'm attaching the related Cisco doc.
Thanks for your help!
Frank
Reza Sharifi Tue, 01/05/2010 - 09:47
  • Cisco Designated VIP,
    2017 LAN
Hello Frank,
According to your PDF file a 2821 can install 2 HWIC-1FE and 1 HWIC-2FE
Cisco 2821 1 to 2 may be installed 1 may be installed
Slot 0 to slot 3
Reza
fntowo2009 Thu, 01/07/2010 - 04:50
Reza,
Thanks for your feedback.
I talked/chated with various Cisco product experts. They told me that I can't use both on a C2821 router. It's either 2 HWIC-1FE or 1 HWIC-2FE, not both... Therefore, the C2821 router can support two additional routed fast ethernet ports only...
Frank
