01-05-2010 10:47 AM - edited 03-10-2019 04:52 PM
Is upgrade for CSACSE-1113-K9 appliance running 4.2.0.124 to 5.1 supported?
Solved! Go to Solution.
01-05-2010 11:09 AM
I don't believe that will happen, unless a new Hardware Upgrade Kit is created, look at this for the System memory comparison:
ACS 4.2:
ACS 5.1
Also a new DVD would need to be developed since ACS Appliance Versions are hardware specific...I suppose is not impossible to use the same HW, but I haven't heard of any near plans to occur.
Now keep in mind that the upgrade from ACS 4.X to 5.X is consider a full Migration...lots of differences in the way you manage your Clients, Users, Policies...
HTH.
01-05-2010 10:52 AM
This is not supported...ACS 4.2 can be installed on 1120 with a downgrade...
Note: ACS 5.0 is not supported on 1113 HW.
HTH.
01-05-2010 11:00 AM
Are there plans from Cisco to provide upgrade path from 4.2 to 5.x for 1113 HW?
01-05-2010 11:09 AM
ACS 4.2:
ACS 5.1
HTH.
