incoming call not coming to a specific number
paolo bevilacqua Tue, 01/05/2010 - 12:45
  • Hall of Fame,
    Founding Member
Cannot really understand your problem ? Also you did not mentione what product is about.
Since you are a Cisco employee, recommend you contact your team leader for guidance.
karthike Tue, 01/05/2010 - 16:17
hi
thanks for replying and i have moved out of cisco some month ago
So in my comp we have a cisco call manager version 6..i am adding a cisco 7970 with directory number there is external phone number assigned to it. if i dial through that external number ring is going but there is no ring in the phone , i added several other 7970, 7961 phones they are working fine. only this particular number is not working..so i dont know where will be the problem is so pls let me know point out where to look
karthik
Message was edited by: karthikeyan Gopinathan
Jaime Valencia Tue, 01/05/2010 - 19:41
  • Cisco Employee,
  • Hall of Fame,
    2011
First thing to look at is the incoming GW, do a debug voip ccapi inout or a debug isdn q931 to make sure the call arrives.
Then look at GW config in CUCM, incoming CSS and what it can reach
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
Related Content
