CME w/ VG224
Jan 5th, 2010
I'd like to deploy a VG224 w/ CME v7 via H323, as opposed to SCCP so the analog ports will not subtract from the supported phone count that the ISR will support.
According to everything I can find, if the analog set requires any features other than the basic placing and recieving of calls, SCCP is required.  I have seen some things though that indicate that I could utilize some features via custom scripting (assuming tcl scripts, of which I do not want to recommend due to complexity and lack of support).
Is it accurate that any features outside of placing and recieving calls would not be supported if the VG224 communicates w the CME via H323?
The main feature that my customer requires is call transfer.
paolo bevilacqua Tue, 01/05/2010 - 11:48
  • Hall of Fame,
    Founding Member
Correct. You can support call transfer via TCL/IVR script.
alubenow Tue, 01/05/2010 - 14:37
Has anyone accomplished call transfer via H323 without tcl?
Has anyone built a tcl for call transfer w H323?
paolo bevilacqua Tue, 01/05/2010 - 15:00
  • Hall of Fame,
    Founding Member
You cannot do call transfer without a TCL/IVR script.
The script is provided by cisco in the CME download area.
Please remember to rate useful posts clicking on the stars below.
alubenow Tue, 01/05/2010 - 15:26
I hat to ask, but can you provide that link?  I'm not able to locate the script.
Have you deployed this script and feature?
