MRTG: Etherchannel (Port Monitoring)
Answered Question
Jan 5th, 2010
Q. Can MRTG monitor a etherchannel circuit (3 x 1GB Dot1q) and deliever correct stats?
Q. Does traffic load balance over a etherchannel (Dot1q) circuit?
Colm
Correct Answer by Joe Clarke about 7 years 6 months ago
Load balancing is enabled by default.  Use the "show etherchannel load-balance" command to see the current algorithm.
Overall Rating: 5 (1 ratings)
colmgrier Tue, 01/05/2010 - 12:42
Hi Joe,
Are etherchannels load blanacing  by default on 6500 switches, or do I need to configure globally?
port-channel load-balance {src-mac | dst-mac | src-dst-mac | src-ip
Colm
Correct Answer
Joe Clarke Tue, 01/05/2010 - 13:10
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
