Is virtualization of the new Unified Business Attendant Console Supported yet?
Jan 5th, 2010
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin;}
Customers are NOT happy having to dig up additional HW for the console server. Most have just completed or will be soon, a major server virtualization. With Unity now able to be virtualized and the AC server requirements being fairly basic, this raises some serious questions about the deployment model.
So... I can't find anything specifically stating that one CANNOT run the AC server on a virtual machine but, nothing saying you can either.
Any help out there is appreciated
Sam
Jaime Valencia Tue, 01/05/2010 - 13:52
  • Cisco Employee,
  • Hall of Fame,
    2011
No, it's NOT supported
Cisco Unified Business Attendant Console
You can install the server software for the Cisco Unified Business Attendant Console to a dedicated hardware server or load it on a desktop PC running Windows 2003 Server or Windows 2008 Server. For mission-critical installations, a dedicated hardware server is recommended because shutting off the PC server will cause the Cisco Unified Business Attendant Console to lose Cisco Unified Communications Manager connectivity.
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6789/ps7046/ps7282/product_data_sheet0900aecd805e6a5f.html
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
