Vlan Database
Jan 5th, 2010
I have a Cisco 6509E running IOS 12.2(33) SXI3
The IOS still allows me to run the following command for creating and Delete VLANS
Router# vlan database
and after creating VLANs, it should also create VLAN.dat file under sup-bootflash:  I have looked each and every File System, but couldn't find the VLAN.dat file as I need to delete this file to remove all the VLANs from the switch.
Thanks !
Jon Marshall Tue, 01/05/2010 - 15:13
Thanks !
The vlan.dat file should be stored in const_nvram ie.
6500# dir const_nvram
Jon
Ryan Carretta Tue, 01/05/2010 - 17:33
I'd just like to add something to this.
An Jon mentioned, the file is in const_nvram:
6500-3(config)#do dir const_nvram:
Directory of const_nvram:/
    1  -rw-         856                      vlan.dat
129004 bytes total (128148 bytes free)
However, deleting this will only delete VLANs in the standard (not extended) range.
Here's a quick illustration:
6500-3(config)#do sh vlan
VLAN Name                             Status    Ports
1    default                          active
100  VLAN0100                         active
105  VLAN0105                         active
110  VLAN0110                         active
115  VLAN0115                         active
120  VLAN0120                         active
1002 fddi-default                     act/unsup
1003 token-ring-default               act/unsup
1004 fddinet-default                  act/unsup
1005 trnet-default                    act/unsup
3000 VLAN3000                         active
3005 VLAN3005                         active
3010 VLAN3010                         active
3015 VLAN3015                         active
3020 VLAN3020                         active
3025 VLAN3025                         active
As you can see, I have the default vlans, and additionally I have vlans 100,105,110,115,120 in the standard range, and 3000,3005,3010,3015,3020,3025 in the extended range.
In VTP Server mode, the extended VLANs appear in the configuration and the standard ones do not:
6500-3(config)#do sh vtp stat | i Operating
VTP Operating Mode              : Server
6500-3(config)#do sh run | i vlan
vlan internal allocation policy ascending
vlan access-log ratelimit 2000
vlan 3000,3005,3010,3015,3020,3025
In VTP Transparent mode, they all appear in the config:
6500-3(config)#vtp mode trans
Setting device to VTP TRANSPARENT mode.
vlan 100,105,110,115,120,3000,3005,3010,3015,3020,3025
Looking at the VLAN.dat file (through the jibberish), you will see that only standard vlans are stored here:
6500-3(config)#do more const_nvram:vlan.dat
:[^P
^@^@^@^B^B^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@@(
^C^@^@^@^A100106004016 {KU^_ 'go"^C^Ke;V|^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@
^B^B^@[email protected],^Fhdefault^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^A^A^E\^@^A^@^A^F!^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^VLAN0100^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^A^A^E\[email protected]^@^A^D^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^VLAN0105^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^A^A^E\[email protected]^@^A      ^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^VLAN0110^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^A^A^E\[email protected]^@^A^N^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^VLAN0115^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^A^A^E\[email protected]^@^A^S^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^VLAN0120^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^A^A^E\[email protected]^@^A^X^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^Lfddi-default^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^B^A^E\^Cj^@^A
^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^Rtoken-ring-default^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^C^A^E\^Ck^@^A
^K^@^@^@^@^@^@^@^@^@^@^@^@^@^@^Ofddinet-default^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^D^A^E\^Cl^@^A
^L^@^@^@^A^@^@^@^@^@^@^@^@^@^@^@^@
trnet-default^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^E^A^E\^Cm^@^A
^@^@^@^B^@^@^@^@^@^@^@^@^@^@^@[email protected]^VP^@^@^Cj^@^@^BVkx^A^A^@^@^D^A^@[email protected]^`^@^@^Ck^@^@^S^\^PP^A^A^@^@^D^A^@[email protected]+B ^@^@^Cl^@^@^C^^P^B^A^@^@^C^A^@^A^@^@^@^@^@^@^Cm^@^@^F^S^LX^B^A^@^@^C^A^@^B
The long and short: to delete vlans typically I like to just do a 'no vlan 1-4094':
6500-3(config)#no vlan 1-4094
Default VLAN 1 may not be deleted.
Default VLAN 1002 may not be deleted.
Default VLAN 1003 may not be deleted.
Default VLAN 1004 may not be deleted.
Default VLAN 1005 may not be deleted.
1    default                          active
Jon Marshall Tue, 01/05/2010 - 18:14
Good additional information. One thing to add -
however, deleting this will only delete VLANs in the standard (not extended) range.
True but if you have used vlan database to configure the vlans in the first place you cannot create extended range vlans in that mode.
Jon
