Problems with Route Groups/Lists in CUCM 6.1
Jan 5th, 2010
I'm having a strange issue with my CUCM 6.1 cluster.  We have 3 x SIP trunks going to another cluster (ie. one trunk to each node).  Whenever I point a route pattern down a single trunk, it works fine (on all of the trunks) but as soon as I put one or all of the trunks into a route group then route list and point the route pattern down the new route list, it doesn't work.
Note that it was working earlier - we have recently added a new subscriber.
Any help would be much appreciated!
p.horwood Wed, 01/06/2010 - 13:27
If you have added this new subsciber to a CUCM group that is referenced by your SIP
trunks then this would cause an issue if it does not match
up on all clusters
Nick Halbert-Li... Wed, 01/06/2010 - 13:32
I got it fixed - I ended up doing a "utils dbreplication reset all" on an SSH session to the publisher.
