PIX Static NAT
Jan 5th, 2010
currently In our network we done NAT on the Cisco router were
ip nat inside source static XXX.90.XXX.1
Acl is allowing range of ports ---- 80, 1021 to 1281 from Outside to inside
ip nat inside source static tcp 5500 XXX.90.XXX.2 80
Acl is allowing range of ports ---- 80 from Outside to inside
Now when we are Migrating  to PIX 515E
we are not able to do the same its says duplicate entry for when we adding PAT entry after one to one NAT entry
Since the first NAT statement carries range of port we are unable to break the statement (orelse we need to put 250 NAT entry)
kindly suggest us any solution to Static NAT range of Port or some ideas
thanks in advance
solpandor Wed, 01/06/2010 - 03:27
Hi Vinu
am i right in saying that you want to assign a static nat (using an IP from a block of your IP's) rather than port forward.  If this is the case then on the pix you would enter a static nat to an inside (private IP) and then apply an acl on the outside interface allowing the ports
create Static
1) static (inside,outside) public_ip netmask
create ACL
2)access-list acl_out permit tcp any host public_ip eq 80
then apply the ACL to the outside interace
3)access-group acl_out in interface outside
