Memory stuck for dead process
Jan 5th, 2010
I am getting alerts for router (1800) low on memory.
When checked "sh mem dead" I see a lots of lines for "State Machine Instance" & "SSH Process".
Can we free the memory allocated to thses process. How to prevent this in future.
64531540 0000000028 645314F4 6453158C 001  -------- -------- 61D1D1BC  State Machine Instance
6453158C 0000000076 64531540 64531608 001  -------- -------- 61D1D1BC  State Machine Instance
64531C14 0000000428 6453177C 64531DF0 001  -------- -------- 60121628  SSH Process
645353D8 0000000028 64535118 64535424 001  -------- -------- 61D1D1BC  State Machine Instance
64535424 0000000048 645353D8 64535484 001  -------- -------- 61D1D1BC  State Machine Instance
64535DB4 0000000380 6453591C 64535F60 001  -------- -------- 60121628  SSH Process
64535F60 0000000380 64535DB4 6453610C 001  -------- -------- 60121628  SSH Process
6453610C 0000000028 64535F60 64536158 001  -------- -------- 61D1D1BC  State Machine Instance
64536158 0000000028 6453610C 645361A4 001  -------- -------- 61D1D1BC  State Machine Instance
645361A4 0000000028 64536158 645361F0 001  -------- -------- 61D1D1BC  State Machine Instance
645361F0 0000000032 645361A4 64536240 001  -------- -------- 61D1D1BC  State Machine Instance
Please suggest.
Thanks & Regards,
Laurent Aubert Wed, 01/06/2010 - 18:37
  • Cisco Employee,
You should reload the router to free all this memory during a maintenance windows otherwise the router will do it on its own when it really will go out of memory.
After the reload, if you see the dead memory still increasing, you are facing a memory leak and so should engage the TAC for troubleshooting.
Laurent.
