Router 12.4: Inside -> Outside Source NAT with specific Traffic target
kmmehlkmmehl
Hello!
I have a problem.
I want to Source Nat Traffic going from one internal Host to one Specific External Host (remote system) to a specific IP on an outside Interface.
Any Idea?
Thanks!
E.g
(Traffic from Internal Host 10.1.1.1 Port 25 sent to 8.8.8.8 should get the External IP 3.3.3.3)
rajatsetia
Try this-
ip nat inside source static 10.1.1.1 3.3.3.3 route-map test
route-map test permit 10
match ip address 101
"Not sure if by port 25 you mean source or destination port (assuming the protocol as TCP)"
"for source port 25"
access-list 101 permit tcp host 10.1.1.1 eq 25 host 8.8.8.8
"for destination port 25 "
access-list 101 permit tcp host 10.1.1.1 host 8.8.8.8 eq 25
5 Replies 5
rajatsetia
Try this-
Marwan ALshawi
also you can use this config
ip nat pool pool1 3.3.3.3 3.3.3.3 prefix-length 24 ---- you need to put the requred prefix length (subnet)
ip nat inside source route-map map1 pool pool1
access-list 100 permit tcp host 10.1.1.1 host 8.8.8.8 eq smtp
route-map map1 permit 10
match ip address 100
good luck
if helpful Rate
Thanks Guys.
I made it without a route map... only with the access list defining..
ip nat inside source list 120 pool POOL_EXT overload
will this work also? i cannot test it (yet)
supposed to work
but sometimes with ACL dos not work .. why i do not know
if you got any problem just change it to oneof the ways mentioned above with route-map
good luck
if helpful Rate
Interestingly yes, sometimes acl doesnt work and whenever I faced NAT+ACL situation, I used to get very frustrated (not because I was not aware that I can use route-map but why ACL solution not working was the problem).
Today I got bit of hope as i read one of technology blog  (not tested or verified with Cisco documentation)
It says "route-maps can match against extended access lists, whereas "ip nat inside source list" supports standard access lists only"
If this is true, NAT+route-map is the only solution here
